Kuidas saab vw passat b6 pardatsoki eest. Tegin kõik nähtavad kruvid lahti aga ei taha ikka eest ära tulla. Vaja salongi ventikas kätte saada
Tegin nende piltide järgi nagu siin antud aga ikkagi kuskilt nagu hoiaks kinni. http://www.b6club.ru/viewtopic.php?f=54&t=3144" onclick="window.open(this.href);return false;
Pardatsoki eemaldus
- Mindfreak
- Auto: Passat
- Tänanud: 84 korda
- Tänatud: 107 korda
Re: Pardatsoki eemaldus
http://forums.vwvortex.com/showthread.p ... g-Glovebox" onclick="window.open(this.href);return false;
Pööra tähelepanu lausele:
This is the kicker ..I would remove all the screws and that unit was still tight in there.I thought it was going to snap in half trying to remove it ..
In the 3 pic ,You can see a square hole below the blood stain ...Stick a small flat screw driver in there and give it a small pry ..The glove box fell right out ..This small little piece of ..Was holding it in place .
