Kas kellelgi on infot MK3 VR6 mootori pingutusmomentide kohta.
Eeskätt tunneks huvi väljalaske kollektori mutrite ja sealt edasi ka tuletoru mutrite pingutusmomentide kohta.
VR6 mutrite/poltide pingutusmomendid
- Auto: B5.5 1.9 130, A4 1.9 66kw
- Tänanud: 0
Ega see plokikaas pole millel moment nii tähtis oleks. Minu teada pole autodatas selliseid andmeid
Edit. Keera mõistusega kinni, ehk siis pooleks ja pool pööret tagasi
- Telefon: 56297190
- Auto: VW Golf Mk3 VR6
- Tänanud: 0
- Tänatud: 0
Küsimusele vastus leitud - teema lukku.
Torque Specifications for Volkswagen 2.8L VR6
Bracket/Stay To Body
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Years: All
Note: VR6 - Front Engine Bracket to Body
Type: Dim: Length: Head: Grade:
Camshaft To Cylinder Head
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6 - Camshaft Bearing Cap
Connecting Rod To Crankshaft
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
Note: VR6 - Rod Cap Bolt NOTE: 2 Step: 22 FtLbs + 90 deg
Crankshaft To Engine Block
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
Note: VR6 - Main Bearing Cap NOTE: 2 Step: 22FtLbs+90deg
Cylinder Head To Engine Block
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
Note: VR6 - NOTE: 4 Step: 30FtLbs; 44FtLbs; 90deg; 90deg
Type: Bolt Dim: Length: Head: Hexagon Grade:
Drain Plug To Oil Pan
37 Ft-Lbs
444 In-Lbs
50.17 N-m
Years: All
Note: VR6 - Oil Drain Plug
Engine Block To Transaxle
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
Note: VR6 - Engine to Transaxle - 10mm Bolt
Type: Dim: M 10 X 1.50 Length: Head: Grade:
55 Ft-Lbs
660 In-Lbs
74.57 N-m
Years: All
Note: VR6 - Engine to Transaxle - 12mm
Type: Dim: M 12 X 1.50 Length: Head: Grade:
Exhaust Manifold To Cylinder Head
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR - Nuts & Bolts
Flywheel To Crankshaft
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
Note: VR6 - NOTE: 2 Step: 44 FtLbs + 90deg
Type: Bolt Dim: Length: Head: Grade:
Fuel Rail To Intake Manifold
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
Note: VR6 - Fuel Rail Bolts
Intake Manifold To Cylinder Head
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6
Oil Pan To Engine Block
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6 - Oil Pan Bolts
Oil Pressure Sensor To Engine Block
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6 - Oil Pressure Switch
Oil Pump Cover To Oil Pump Housing
1.5 Ft-Lbs
18 In-Lbs
2.03 N-m
Years: All
Note: VR6 - Long Bolt
Oil Pump Housing To Engine Block
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6 - Short Bolt
Power Steering Pump To Engine Block
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6 - Bracket Bolts
Pressure Plate To Flywheel
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6 - Pressure Plate Bolts
Pulley To Water Pump
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6 - Water Pump Pulley Bolts
Starter To Transaxle
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6 - Starter Bolts
Timing Chain/Belt Pulley To Sensor Holder
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
Note: VR6 - Timing Belt Idler Bolt
Timing Chain/Belt Sprocket To Camshaft
74 Ft-Lbs
888 In-Lbs
100.33 N-m
Years: All
Note: VR6 - Camshaft Sprocket Bolt
Timing Chain/Belt Sprocket To Intermediate Shaft
74 Ft-Lbs
888 In-Lbs
100.33 N-m
Years: All
Note: VR6 - Intermediate Shaft Bolt
Timing Chain/Belt Tensioner To Engine Block
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6 - Timing Belt Tensioner Nut
Type: Dim: Length: Head: Nut Grade:
Torque Converter To Flexplate/Driveplate
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
Note: VR6
Valve Cover To Cylinder Head
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
Note: VR6 - Valve Cover Retaining Nuts
Vibration Damper/Hub To Crankshaft
332 Ft-Lbs
3984 In-Lbs
450.13 N-m
Years: All
Note: VR6 - Vibration Damper Bolt
Water Pump To Water Pump Housing
9.5 Ft-Lbs
114 In-Lbs
12.88 N-m
Years: All
Note: VR6
Water Pump Housing To Engine Block
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Years: All
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
37 Ft-Lbs
444 In-Lbs
50.17 N-m
Years: All
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
55 Ft-Lbs
660 In-Lbs
74.57 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
44 Ft-Lbs
528 In-Lbs
59.66 N-m
Years: All
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: VR6
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
1.5 Ft-Lbs
18 In-Lbs
2.03 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
74 Ft-Lbs
888 In-Lbs
100.33 N-m
Years: All
74 Ft-Lbs
888 In-Lbs
100.33 N-m
Years: All
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Years: All
Note: VR6
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: All
332 Ft-Lbs
3984 In-Lbs
450.13 N-m
Years: All
9.5 Ft-Lbs
114 In-Lbs
12.88 N-m
Years: All
Note: VR6
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Years: All
Note: VR6
