Monday,06,April,2020,17:47:12:37101
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0
Data version: 20190115 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ3CZ6P074768 License Plate: CMI279
Mileage: 225920km-140380mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ6P074768 Mileage: 225920km-140380miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-906-056-BLR.lbl
Part No SW: 06F 906 056 AM HW: Hardware No
Component: MED9.5.10 G00 9970
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 18800 205 132204
VCID: 74B4305E5F131A2201-8020
3 Faults Found:
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Mileage: 223076 km
Time Indication: 0
Date: 2020.01.25
Time: 13:31:37
Freeze Frame:
RPM: 1400 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 0.0°C
001431 - Thermostat for Mapped Engine Cooling (F265)
P0597 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 225034 km
Time Indication: 0
Date: 2020.02.26
Time: 09:30:44
Freeze Frame:
RPM: 1920 /min
Load: 23.9 %
Speed: 30.0 km/h
Temperature: 76.0°C
012425 - Signal Line for Fuel Pump Electronics
P3089 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 225367 km
Time Indication: 0
Date: 2020.03.07
Time: 17:16:47
Freeze Frame:
RPM: 1520 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 11.0°C
Readiness: 0000 0000
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658136051
Coding: 0013710
Shop #: WSC 00028 028 00001
VCID: 2F698A09ABBAB4C169-807A
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 Q HW: 3C0 907 044 Q
Component: ClimatronicPQ46 042 0202
Revision: 00042004 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
3 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 254
Reset counter: 34
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 12:35:48
01810 - Actuating Motor for Temperature Flap; Right (V159)
Freeze Frame:
Fault Priority: 3
Reset counter: 34
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 12:35:49
00710 - Defroster Flap Positioning Motor (V107)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 100
Reset counter: 34
Mileage: 224488 km
Time Indication: 0
Date: 2020.02.14
Time: 08:40:42
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000003530533
Coding: 088E8F0700041A00000A00000F00000000095D435C0000
VCID: 3068880AAFBFB2C661-8064
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 00028
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 6
Reset counter: 249
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 11:23:00
Freeze Frame:
ON
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 C HW: 3C0 909 605 C
Component: 03 AIRBAG VW8 028 2421
Revision: 07028000 Serial number: 0038XSBBFU8I
Coding: 0012339
VCID: 26629C74876DCE00B1-8072
Subsystem 1 - Serial number: 6332MSME0B350605
Subsystem 2 - Serial number: 6342MSME0B352346
Subsystem 3 - Serial number: 6351HTS65CHEARR2
Subsystem 4 - Serial number: 6361HTS614FEIKD2
Subsystem 5 - Serial number: 6371VTS614FE5AC2
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 B HW: 3C0 953 549 B
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507E
Coding: 0000111
VCID: 2B6D8205BB86AC2549-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 F HW: 3C0 920 870 F
Component: KOMBIINSTRUMENT VD1 4038
Revision: V0033000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05830011C
Coding: 3DFD0C04C21002
VCID: 216796679374E86F99-8074
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 H HW: 3C0 959 433 H
Component: IMMO 038 0364
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
Subsystem 1 - Part No: 3C0 905 861 C
Component: ELV 023 0350
3C0905861C ELV 023 0350
7 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
Freeze Frame:
Fault Status: 00110000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 14
Mileage: 0 km
Time Indication: 0
02861 - Electronic Steering Column Lock Check Sum Error
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 31
Mileage: 0 km
Time Indication: 0
02815 - Steering Column Lock; Supply Voltage for Locking Motor
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 20
Reset counter: 34
Mileage: 0 km
Time Indication: 0
02816 - Steering Column Lock; Enabling Wire from Diagnostic Interface
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 225918 km
Time Indication: 0
Date: 2020.04.06
Time: 17:29:53
02817 - Steering Column Lock; Enabling Wire from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 34
Mileage: 225918 km
Time Indication: 0
Date: 2020.04.06
Time: 17:29:53
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 33
Mileage: 0 km
Time Indication: 0
02811 - Control Module for Electronic Steering Column Lock (J764)
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 8
Reset counter: 34
Mileage: 0 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000181
VCID: 3672BC2447DD6EF031-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3276B41057A986D411-8066
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0453
Coding: 00910A0801860E763804941570084F0B603C00
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 3771BA214BC2648929-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E2049427
Coding: 0040400
VCID: 3375B21D5BAE9CED09-8066
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
1 Fault Found:
01036 - Electric Window Thermal Protection Active; Rear Left
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3474B01E5FD39AE201-8060
End-------------------------(Elapsed Time: 01:46)--------------------------
www.Ross-Tech.com
Coding: 0000072
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Mileage: 223076 km
Time Indication: 0
Date: 2020.01.25
Time: 13:31:37
Freeze Frame:
RPM: 1400 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 0.0°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 225034 km
Time Indication: 0
Date: 2020.02.26
Time: 09:30:44
Freeze Frame:
RPM: 1920 /min
Load: 23.9 %
Speed: 30.0 km/h
Temperature: 76.0°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 225367 km
Time Indication: 0
Date: 2020.03.07
Time: 17:16:47
Freeze Frame:
RPM: 1520 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 11.0°C
Coding: 0013710
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 34
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 12:35:48
Freeze Frame:
Fault Priority: 3
Reset counter: 34
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 12:35:49
Freeze Frame:
Fault Priority: 3
Reset counter: 34
Mileage: 224488 km
Time Indication: 0
Date: 2020.02.14
Time: 08:40:42
Coding: 00065493
Shop #: WSC 00028
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 249
Mileage: 216348 km
Time Indication: 0
Date: 2019.09.11
Time: 11:23:00
Freeze Frame:
ON
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Coding: 0012339
Coding: 0000111
1 Fault Found:
Coding: 0007105
7 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 14
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 31
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 20
Reset counter: 34
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 225918 km
Time Indication: 0
Date: 2020.04.06
Time: 17:29:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 34
Mileage: 225918 km
Time Indication: 0
Date: 2020.04.06
Time: 17:29:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 33
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 34
Mileage: 0 km
Time Indication: 0
Coding: 0000181
Coding: 0000180
Revision: 013
Coding: 0000011
Coding: 0040400
Coding: 0000144
1 Fault Found:
Coding: 0000144
