Vw Scirocco GTX '85 - Arūnas
Moderaator: HawkHill
- Telefon: 2147483647
- Auto: Scirocco GTX
- Tänanud: 0
- Tänatud: 0
Tere. See on minu scirocco Ma ei räägi häasti eesti keel, kuid parem räägin inglise keel I bought this car in 2009-12-18, previous owner had this car all 12 years Made in 1985, 66kw carb + gaas (=gaas), like we call in netherlands; gay engine. But in condition like in foto, this car survive less than month, then it get something like russian tuning... Oficialy it was not my fault, so lets think like that Of course thats not finish: Later... After later --> --> The part which i cut out tells about previous owner - he had small accident. --> Scirocco in action and my other toy Porsche 924 turbo --> --> Now front looks like that , i know its sh*t, but its very hard to find kapott in good condition, for paint job i hadnt time. And i cant remove that gay style air catcher, it will comes of with paints... Before month i had a trip from Amsterdam to Kaunas, before poland capital engine gets overheat - first cilinder head camera had something like tunnel with water chanel, so 400km we had ride 40-60km/h totaly 10hours... We put dirty snow from road to water system and thats made heater stuck, heater doesnt work and for next day is another trip Latvia, Estonia, Finland (lapland, rovaniemi) in nght time, even not in garage i had cleand that radiator. Later in Finland when i decide to ride with gasoline (fins are to rich for gaas, or to poor for gaas systems, anyway they don't have gaas), then fuel pomp stopped to give fuel for carb. Valves in pomp doesn't work, so i put one valve from vacum system, and drive like that. Later in lapland i bought new pomp. Ja üks foto behind some kind of Tallinn castle
Nüüd ma soovin magama, 'so like' sa räägite tsau! (for now)
Viimati muutis Max, 23 Jaan 2011, 19:58, muudetud 1 kord kokku.
Ma olen leedukas :)
- Auto: VW Scirocco GT
- Tänanud: 0
- Tänatud: 0
Re: Arūno Scirocco GTX
Nice ride!
Oh, not to get banged about the language skill here, try to use English!
("Ma olen leedulased" means "I am Lithuanians")
My carbon-footprint is bigger than Yours! Famiglia di Rocco.
- Telefon: 53331514
- Skype: venekt
- Auto: Liiga palju autosid vist
- Tänanud: 0
- Tänatud: 3 korda
Hello
As we can read You have lot of fun with Your Scirocco.
Good that You still will ceep it alive.
I think in Lithuania You can find better engine with small money, but if this one is in good condition, why not ride with thisone.
Regards
Uno
Regards
Uno
- Telefon: 56660496
- Auto: vw golf mk1 2,0L G60 ,MB CLK 200 Kompressor
- Tänanud: 0
however... you can also do an engine swap.You can throw in a 2,0 ABA engine without big modifications. A bit of OT:But how much horsepower does your 924 Turbo produces?
- Tänanud: 0
- Tänatud: 0
Thanks for lesson man, than how to write lithuanian (only one)?Reto kirjutas:Nice ride!
Ma olen leedukas :)
- Tänanud: 0
- Tänatud: 0
Yes engine now is in perfect condition, because of water in oil piston rod bearing plates doesn't get oil - that gets water, so i changed piston rod bearing plates, piston rings, all gaskets and many many other small things. But its anyway gay engine for pension age mans if i turn car 90 degrees on the road and pull full gas, wheels spins not because of engine power, but tires doesn't hold car on road, then loose contact and wheels can spinuno kirjutas:Hello
Regards
Uno
Viimati muutis Arūnas, 22 Jaan 2011, 01:43, muudetud 1 kord kokku.
Ma olen leedukas :)
- Tänanud: 0
- Tänatud: 0
I would swap, but oficialy in Lithuania i can put engine which has no more than +30% power, that means if my engine is 66kw i can put something like 85kw engine example 2E (golf mk 3, gti), or if i put example that ABA engine, then officially i can't get TA (its like technical side look), and i can be married with that car, because like that i can't rewrite car for another person name. The best way i think would be to use my block (only for number), audi S2 pistons, buy another KR engine (in Lithuania that is cheep - around 120-150eur) use that 16v head, crankshaft, camshafts ant other stuff, put on head some nice turbo, g60 brain and should be perfect. But thats big job, and car needs to stay longer. Thats why i think first older kid porsche needs to bee fixed. Now it has 170hp, but its built in 1979, turbocharger from these times is shit K26 - cold side of this is smal, as i had seen more it make air hot, than gives power + he don't have intercooler, i want to put another turbo from saab. In summer i come back to Lithuania (now i stay in Holland) with gasket set for all engine and other stuff, and then gonna do something. That should be in last month, but scirocco die in poland, so that sucks And i have stupid question: do in Estonia you need to pay tax for roads, or something like everyone who has car pay example 100eur for years?PRIM0 kirjutas:however... you can also do an engine swap.You can throw in a 2,0 ABA engine without big modifications. A bit of OT:But how much horsepower does your 924 Turbo produces?
Viimati muutis Arūnas, 22 Jaan 2011, 01:48, muudetud 1 kord kokku.
Ma olen leedukas :)
No tax for roads. Just car insurance and TÜV(technical inspection).
btw, nice scirocco. More daylight pics;)
- Tänanud: 0
- Tänatud: 0
, now its not so nice needs to get polish, acrylic red + sun = color like a skin of pig. And one video. P.S. sound from engine is because of burned gasket between head and exhaust manifold and only one rear wheel can brake. These other parked cars, military later took inside http://www.youtube.com/watch?v=gOp7VTR87ys[/video]
Ma olen leedukas :)
- Tänanud: 0
- Tänatud: 0
Re: Vw Scirocco GTX '85 - Arūnas
http://www.youtube.com/watch?v=2AeXp_eU ... r_embedded[/video]
Head is lovered only 0.16mm, spark plugs is original NGK BUR6ET, now i put BP7ES (colder) and engine does same still. That happens when i pull gas till 3000rpm, hold pedal in same position and then turn ignition off. So this detonation can't be problem of bad ignition timing, or vacuum lines, because ignition is of and spark plugs doesn't spark.
Ma olen leedukas :)
- Telefon: 56643833
- Auto: Passat B7, HIGHLINE; OhtlikPeldikEestiLiikluses; BMW 535d
- Tänanud: 5 korda
- Tänatud: 0
Thats a nice car you have here (Y) Keep up the good work!
ma olen leedukas=I am lithuanian
- Tänanud: 0
- Tänatud: 0
I love this crazy language man, in lihuania i am ledukas means; i am small peace of ice, like ice's in cola Oh guys if you would know how much anecdotes we have about estonians and eesti keel, you would think f*ck [VW Bot: "Keel korda!"] these lithuaniansjyrtsilla kirjutas:Thats a nice car you have here (Y) Keep up the good work!
For this you dont need, speek lithuanian And please don't take it serious, its just friendly jokes about slow brothers from north Peace.
Važiuoja du estai liftu.
Liftas užstringa.
Estai stovi. Praeina 10 minučių, 20, 30…
Galų gale vienas estas paklausia kito:
- Eee…. Kaažžkkooo lėėėttaai vaaažžžiuoojjaaamm…
Viimati muutis Arūnas, 27 Jaan 2011, 00:38, muudetud 1 kord kokku.
Ma olen leedukas :)
Don't worry!! No bad feelings here, mate!! People always make jokes about better nations!!;)
Greetings to Lithuania (or Holland)!! And welcome to the club!!
About the sciro... you have to lose the stripes!! They ruin the whole look of the car!! Apart form the stripes the car looks quite cool!!
I love Volkswagening!!:)
- Auto: T***a P***s+
- Tänanud: 64 korda
- Tänatud: 16 korda
This is a typical symptom of the non-working wax element.Arūnas kirjutas:That happens when i pull gas till 3000rpm, hold pedal in same position and then turn ignition off. So this detonation can't be problem of bad ignition timing, or vacuum lines, because ignition is of and spark plugs doesn't spark.
No. 5 in this picture
- Tänanud: 0
- Tänatud: 0
As i remember i took this part from other carb just 1.6liter, my old one was plastic, other aliuminium so i put this. Can you explain whats happen inside of carb when that part doesn't work?pppp kirjutas:This is a typical symptom of the non-working wax element.Arūnas kirjutas:That happens when i pull gas till 3000rpm, hold pedal in same position and then turn ignition off. So this detonation can't be problem of bad ignition timing, or vacuum lines, because ignition is of and spark plugs doesn't spark.
Ma olen leedukas :)
- Tänanud: 0
- Tänatud: 0
Before X days finally i removed that ugly air cacher, that was glued only with strong silicone
And ugly exhaust rear side, which is made by style kaks on parem kui üks. But that another makes to much noise so exhaust system is still not done.
And the newest thing, another passenger side window, before i thought even in Lithuania can't happen like that for car like this.... But that was in Holland
I already get other window, (it wasn't so simply in Holland) - i got that from netherlands scirocco forum owner , and also bought the small same side window, my old one was not tinted, but all others are tinted. So now i need fix exhaust, and replace red painted parts to original black in the interior, and i think remove white strips and polish all car
Viimati muutis Arūnas, 18 Veebr 2011, 00:28, muudetud 1 kord kokku.
Ma olen leedukas :)
- Telefon: 56660496
- Tänanud: 0
the exhaust looked really very "special" , glad you got that sorted out.Also i think its a good idea to remove the white stripes.After all , its not a Dodge Viper.
- Tänanud: 0
- Tänatud: 0
Hi, so some updates. That was when i bought
And now it looks better And new nice stuff for future AEM wideband straight from latvian brother
Before tuning removal
And after
Wiper strips are already gone, now i waiting weekend to use these good things
And i hope that later i will get these wheels
And i have one more question, do you organize some vw owners meetings of this club?
And after
Viimati muutis Arūnas, 21 Apr 2011, 00:32, muudetud 1 kord kokku.
Ma olen leedukas :)
- Telefon: +3725204426
- Auto: VW Polo 82/VW Caravelle 86
- Tänanud: 0
- Tänatud: 0
Nice work, it looks like a car again.
Lower it!
Lower it!
- Telefon: 56660496
- Tänanud: 0
to answer your question-yes , we do have club gatherings.They are regional , i. e. Tallinn , Tartu , Pärnu etc. all have cometohethers for their own cars.But everyone is welcome. BTW , love what you are doing with the car so far , removind all the cheap tuning and putting some coolness back into the car....keep up the good work.
- Tänanud: 0
- Tänatud: 0
I know But I'm not in home, thats why everything is going so slow... Till summer i gonna play with small things, and for summer i have a bigger planKermo kirjutas: Lower it!
Ma olen leedukas :)
- Tänanud: 0
- Tänatud: 0
Thanks for answer and nice words, i think that would be nice to come some day to see that great eestima and what kind of wheels you ride therePRIM0 kirjutas:to answer your question-yes , we do have club gatherings.They are regional , i. e. Tallinn , Tartu , Pärnu etc. all have cometohethers for their own cars.But everyone is welcome. BTW , love what you are doing with the car so far , removing all the cheap tuning and putting some coolness back into the car....keep up the good work.
Ma olen leedukas :)
