[Škoda] Skoda Superb MK2 mõningad probleemid
Küsimused, probleemid ja arutelud seoses elektroonikaga.
rainis1225
Auto: Golf III
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas rainis1225 » 19 Dets 2018, 15:31
Nimelt sai siis oma Superbile kaabel taha pandud, kuna tahtsin teada miks ei tööta footwell lights aga selgus ka muid probleeme millega tahaks tegeleda. Kuna Skoda oma foorum on suht surnud, ja sealt mingeid vastuseid ei saa siis prooviks siit.
Masin aastast 2009 ja mootoriks 2.0 103kW.
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 QP HW: 03G 906 021 AB
Component: R4 2,0L EDC G000AG 2893
Revision: --H09--- Serial number:
Coding: 0000078
Shop #: WSC 33361 790 00000
VCID: 7DF789B6248604F6F0B-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AF HW: 3T0 907 044 AF
Component: Climatronic 122 0203
Revision: 00003001
Coding: 0100000000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 76E5969AC9B057AEB11-8023
3 Faults Found:
9474417 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Reset counter: 198
Mileage: 287195 km
Date: 2107.14.14
Time: 17:57:13
9474418 - Motor for Front Air Distribution Flap
B1091 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 289850 km
Date: 2108.14.07
Time: 12:26:04
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 287194 km
Date: 2107.14.14
Time: 15:46:57
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 A HW: 1K0 937 086 A
Component: BCM PQ35 M+ 020 0358
Revision: 00020000
Coding: 40990AB8D80508C040080084110081A405711BAE432081605C4040000000
VCID: 2E557EFA79602F6E391-807B
Subsystem 1 - Part No: 3T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 14010 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 190109 05 54 0402
Coding: 0730ED
5 Faults Found:
00061 - Footwell Lights
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Reset counter: 158
Mileage: 279572 km
Time Indication: 0
Date: 2040.14.08
Time: 18:35:43
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 9
Reset counter: 191
Mileage: 290772 km
Time Indication: 0
Date: 2044.14.30
Time: 14:50:11
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
00985 - Right Tail Light (M2)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 186
Mileage: 293798 km
Time Indication: 0
Date: 2046.14.25
Time: 19:27:17
Freeze Frame:
Term 15 On
Voltage: 13.40 V
ON
ON
Term 50 Off
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 197
Mileage: 295160 km
Time Indication: 0
Date: 2047.14.16
Time: 18:30:05
Freeze Frame:
Term 15 On
Voltage: 13.70 V
ON
ON
Term 50 Off
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 197
Mileage: 295167 km
Time Indication: 0
Date: 2047.14.16
Time: 20:33:18
Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
ON
Term 50 Off
OFF
OFF
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 A HW: 7N0 959 793 A
Component: TSG FA H03 0190
Revision: Serial number: 0000100629990
Coding: 011D0220DE00121002
VCID: 40893042D3F4A91EDBD-8015
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 39
Reset counter: 131
Mileage: 277494 km
Time Indication: 0
Date: 2039.14.09
Time: 08:22:29
Viimati muutis argo, 25 Juul 2019, 21:22, muudetud 1 kord kokku.
Mine “Elektroonika - VAG”
