P0444 - EVAP Purge Control Valve (N80): Circuit Opengolfi_vend kirjutas:Pane kirja koodid...
Kas tagumine lambda ei löö avariise? Pead laskma lambdad välja kirjutada.
P0418 - Relay for Secondary Air Injection Pump (J299): Malfunction
P0413 - Secondary Air Injection System Valve (N112): Open Circuit
P0056 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit: Malfunction / Open Circuit
P0036 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
P0276 - Fuel Injector #6 (N84): Short to Ground
P0261 - Fuel Injector #1 (N30): Short to Ground
P0267 - Fuel Injector #3 (N32): Short to Ground
P0273 - Fuel Injector #5 (N83): Short to Ground
P0270 - Fuel Injector #4 (N33): Short to Ground
P0013 - Bank 1: Camshaft B (Exhaust): Position Actuator Malfunction
Avarii asja ma ei oska öelda.
