Sõbral on abi vaja...
Küss on väga lihtne, et kui makk on lukku läinud, mismoodi selle lahti saaks.
VW Passat 1998.a originaal makk lukus?
jimny
- Auto: VW Passat b8 1,4TSI DSG 110kW, MB S123 200TD 44kW
Viimati muutis argo, 14 Mär 2012, 06:13, muudetud 1 kord kokku.
[b]VW Passat B8, 1,4TSI DSG, MB 200D S123, 2,0 diisel[/b]
leidsin mingi sellise õpetuse:
We have a 2001 Jetta, replaced the battery and the radio was in SAFE mode. It came up with 1000 automatically. No Owners Manual.
In reading the above entries, here's how I fixed it. Pulled up the spare tire deck, and along the left side of the spare tire, there is a sticker with a VWZ# and right below that # is a 4 digit number. Then I followed these steps.
Perform the steps in exactly the following order:
1. Turn on the Radio. "Safe" will appear in the display.
2. After 3 seconds, the number "1000" will appear in the display.
3. Use the radio station preset buttons 1 to 4 to enter the code number found on your Radio Card. (which was in the first page of Sound manual
Use preset button 1 to enter the first digit in the code number. Use button 2 to enter the second digit, etc. The value range for each of the 4 digits is "0-9". The digit will increase by 1 each time you tap the preset button. The number returns to "0" after 9".
4. After you finish entering the code, press the right side (">") of the SEEK button for longer than 2 seconds until you hear an audible signal.
5. After the audible, Monsoon displayed on the screen and ouila!, the Sounds of Music.
jimny
aga kui näitkeks koodi ei tea?copilot kirjutas:leidsin mingi sellise õpetuse:
3. Use the radio station preset buttons 1 to 4 to enter the code number found on your Radio Card. (which was in the first page of Sound manual)
Kas nad on mingi vaikimisi koodiga kohe tehasest tulnud?
Et ehk prooviks seda? Aga seda ka ei tea, mis see on?
tõsta üles tagavararatta kate, vasakul nurgas peaks olema üks kleeps, seal mitmed koodid jms, kirjas ju kus peaks olema kood!
