Kuidas saab koodi sisestada???
tanel556
Lugemata postitus Postitas tanel556 »
kood olemas aga ei saa sisestada kuidagi
Viimati muutis tanel556, 12 Sept 2012, 15:26, muudetud 1 kord kokku.
Tänanud: 54 korda
Tänatud: 63 korda
Re: Kuidas saab koodi sisestada???
Hoia all nuppe M ja VF ning siis kui tuleb ette 1000 saad koodi sisestada.
[ Postitus tehtud Windows Smartphone'i kaudu ] Pilt
tanel556
panin maki tööle tuleb ette safe ja siis hoiad neid nuppe all ja tuleb sinna taha nr 2 ja muud midagi , hoidsin mingi 2-3 min aga ei midagi ikka ainult safe 2
tanel556
või peab kauem hoidma?
Koodi ikka tead? :D Kui ei, siis sellekspuhuks ka oma foorum, kus end regades on võimalik raadio seerianumbrit kasutades koodi saada.
Aga muidu:
1.Turn on radio. The radio display shows "SAFE".
2.Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
3.Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
4.Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
5.The radio should unlock and be usable shortly afterwards.
6.If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
volksvaagen
Lugemata postitus Postitas volksvaagen »
Aga makil pole ju AM nuppu
volksvaagen kirjutas:Aga makil pole ju AM nuppu
My bad! :oops: Kuna neid Alpha, Beta, Gamma, jne... Audi/VW originaal raadioid on mitut versiooni, siis ei süvenenud tähelepanelikult ülemist pilti. Netifoorumitest aga jäi silma 2 asja, et VW ja Audi Gamma raadiod natuke erivad vms. ja kui juba kiri "SAFE 2" ees, siis pidavat raadio "lukus" olema ja pidavat päästma tunniajane voolukatkestus? :roll:
Tänatud: 215 korda
Ootama pead süüde sees tund või 2 olenevalt mitu korda on kood valesti sisestatud. Pane makk sõiduajal käima ja tee veidi pikkem sõit, aitab ka.
golfi_vend kirjutas:Ootama pead süüde sees tund või 2 olenevalt mitu korda on kood valesti sisestatud. Pane makk sõiduajal käima ja tee veidi pikkem sõit, aitab ka.
Vb. sain siis Ing. jutust valesti aru ja voolukatsestust siiski teha ei tule? :oops:
tanel556
peale 1h hakkas koodi küsima
Tänud :wink:
Mine “Audio ja video”
