Mure selline, et peale spidobloki lahtivõtmist enam tehase immo võtit ära ei tunne.
Auto läheb korras käima ja sureb sekundi pärast välja, seda teeb ta mõlemi originaalvõtmega.
Proovisin akuklemmi maas hoida 20min, kuid ei aidanud?
Autoks 1998a. Golf IV.
Kas on mingi muu võimalus autole võti selgeks teha? Peale välja suremist jääb kollane auto/võtme tuluke viljuma armatuuris (immo).
Asjaga suhteliselt kiire,
Tänud kõigile ette ära.
Kuidas restartida Golf IV immot
- Tänanud: 45 korda
- Tänatud: 204 korda
Re: Kuidas restartida Golf IV immot
Kasutaja dellu Tallinnast ilmselt saab aidata.
priidu6
- Auto: Golf III 1.6 / Golf IV 1.9
One thing to try before anything else is to switch on the ignition(engine not running), press the throttle pedal to the floor - switch off ignition - release the throttle pedal - turn ignition back on. Leave it switched on for ten or fifthteen minutes to allow the cars electronics to cycle. After this try starting the car. If it still will not start then you are looking at a problem with either the chip in the cars key, the antenna/wiring in the steering coluum, or the cars ECU. This will require a full scan to find it out.
Maybe when you remove cluster ,you pill little hard harness and pull wires from key reader. They where in but not all the way. Because that wires from key reader goes in cluster harness.
http://www.myturbodiesel.com/forum/f5/i ... 4-a-16437/" onclick="window.open(this.href);return false;Your immo doesnt change unless you change hw or reprogram it. Your fault says the pick up coil. It may be a loose or unplugged connector. It is attached on the ignition switch. I helped a dead car on the highway the other day that just needed plug wiggled. Weak batteries also can kick in the immo lockout. It times out for max 255 min or 4hours. Let car sit with battery charger with ignition on to time out. You can also check instruments field 22 or 24 (I forget) and it tells you the lockout minutes. Call me if you like. I'm still on the road though.
http://forums.tdiclub.com/showthread.php?t=271900" onclick="window.open(this.href);return false;
http://www.myturbodiesel.com/1000q/mult ... di-FAQ.htm" onclick="window.open(this.href);return false;
http://www.myturbodiesel.com/1000q/mult ... udi-vw.htm" onclick="window.open(this.href);return false;
- Tänanud: 45 korda
Kõik tore, kuid olen näinud autot, mis unustas lihtsalt päevapeale võtmed ära ja aitas ainult uuesti sobitamine.
Tänud kiirete vastuste eest,
Proovisin selle gaasi ja süüte sees hoidmise 20min ära, kuid ei aidanud.
Katsun kasutaja delluga ühendust saada.
priidu6
Huvi pärast küsiks, kas võtsid akult juhtmed maha enne spidoploki näppimist?
Tavaliselt soovitatakse enne elektrisüsteemi kallale minekut aku klemmid lahti ühendada. Seda eriti uuemate autode puhul. Aga vaevalt, et see sinu masina puhul väga suur probleem on. Vaja lihtsalt asjatundjat vajalike seadmetega.
