Saturday,28,December,2013,18:53:43:01666
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVGZZZ1TZ5W013391 License Plate: TOURAN
Mileage: 403040km-250437mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 69
VIN: WVGZZZ1TZ5W013391 Mileage: 403040km/250437miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC 6246
Shop #: WSC 01324 785 00200
VCID: 67DD49D9566B5626359-8032
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A7BC0AD75591BCE9A7-806F
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - -
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000806095
Coding: 088B8F020004200000120C000000000000
VCID: 377DD999464B06A6659-8062
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 00000
7 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
00978 - Lamp for Low Beam; Left (M29)
01495 - Bulb for High-Beams; Left (M30)
01499 - Bulb for High-Beams; Right (M32)
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit
02394 - Parking Light Left Front (M1)
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD07PSXF
Coding: 0012338
VCID: 3467EE95573DEDBE40B-8061
8 Faults Found:
00595 - Crash Data Stored
000 - - - MIL ON
01214 - Crash Data for Belt Tensioner Stored
000 - - - MIL ON
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent - MIL ON
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
001 - Upper Limit Exceeded - MIL ON
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
002 - Lower Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 306FE285A325D19E243-8065
1 Fault Found:
00889 - Horn (H)
007 - Short to Ground
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0714
Coding: 0007103
Shop #: WSC 12345 205 55619
1 Fault Found:
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 2A5BF0ED85F9AB4EEA7-807F
1 Fault Found:
02085 - Incorrect Control Module Installed
000 - -
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001045180688
Coding: 3D0F5340078002
Shop #: WSC 16000 205 96525
VCID: 275D09D996EB9626F59-8072
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 172
Mileage: 403045 km
Time Indication: 0
Date: 2000.00.00
Time: 00:02:16
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0714
No fault code found.
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000052
VCID: F4E7AE9597BD2DBE00B-80A1
1 Fault Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.0 1401
VCID: 2F6DE1F9BE1BCE663D9-807A
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 3040 km
Temperature: 19.0°C
Voltage: 11.70 V
Voltage: 11.60 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084B0100
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000052
VCID: F5E193919CC734B6375-80A0
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0842570
Shop #: WSC 28461 895 1106894
VCID: 2D51FBF1B417BC760F5-8078
5 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit - Intermittent
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
01303 - Telephone Transceiver (R36)
Address 69: Trailer
Cannot be reached
End ---------------------------------------------------------------------
Touran ei käivitu. KORRAS!
- Tänanud: 44 korda
- Tänatud: 202 korda
Minu kätte jõudis siis masin sellise eelinfoga, et kütus sai otsa ja peale täitmist ja välise pumbaga õhutamist masin enam ei käivitu. Ise pole ka praegu aega eriti sellega tegeleda ja ilmselt saab käed mustaks antud masinaga alles 2 nädala pärast. Senikaua, ehk keegi teab, mis viga on? Eelinfoks, et Check Engine ja Eelsüüte spiraali tuled ei süti koos süütega. Ise kahtlustan, et aju läbi kärsand.
Viimati muutis R36, 10 Jaan 2014, 17:34, muudetud 1 kord kokku.
Re: Touran ei käivitu
Mootori ecu sisemine viga vähe tõenäoline.
Tähelepanu äratab: 19-CAN Gateway -- Status: Malfunction 0010
Kaitsmed, lisa-immo kõigepealt kontrollida ja siis can võrgustik.
- NOTFAST
- Telefon: 5141947
- Tänatud: 4 korda
Laadi aku korralikult täis ja vaata siis uuesti üle. See tee esimesena, kuna ilmselt on selle ketramisega aku madalat pinget saanud.
- Tänanud: 44 korda
Aku on korralik ja laetud.
- Tänanud: 44 korda
Välismaa foorumid soovitavad kontrollida korraliku pinget aku klemmidel. Samas ei kuulnud ka pumba töötamist koos süütega. Eks kui Eesti pinnale tagasi jõuan hakkan möllama.
Samas oskab keegi öelda, kus neil kytusepump on ja kuidas sinna ligi pääseb?
- NOTFAST
- Telefon: 5141947
- Tänatud: 4 korda
Hakkab juba looma. Just rääkisin ju Sulle sellest akuvärgist. Mul oli kunagi samade või sarnaste näitudega auto. Esiteks laadisin aku täis ja võtsin klemmid maha, siis tahtis veel akende jms tutvustamist, Kustutasin vanad veakoodid. Midagi oli veel aga ka viga võis peituda etteande pumbas, mis peaks tal paagis asuma. Tavaliselt on istme all neil luuk, kust pääseb pumba juurde. Kuidas sellel autol on, ei tea, sest pole sinna asja olnud. Mittetöötava pumba korral võidigi kedrata niikaua, kuni aju ei saanud enam vajalikku pinget ja läks nö. lolliks.golfi_vend kirjutas:Välismaa foorumid soovitavad kontrollida korraliku pinget aku klemmidel. Samas ei kuulnud ka pumba töötamist koos süütega. Eks kui Eesti pinnale tagasi jõuan hakkan möllama.
Viimati muutis NOTFAST, 30 Dets 2013, 17:25, muudetud 1 kord kokku.
- Tänanud: 44 korda
Nii viga ilmselt käes. Aju kolmele suurele vooluklemmile vajalikku pinget ei jõua. 0.8V, väga nukker. Samas süüde sees klemmil ilusti olemas. Kohe istutan ennast skeemide sisse.
- Tänanud: 44 korda
Siiski sinna klemmidele mida mõtlesin voolu jõudma ilma ajuta ei peagi. Ehk siis süütevooluga äratatakse aju üles, aju annab voolu releele, misjärel jõuab ajuni juba vool suuri juhtmeid pidi.
Aju on siiski vigane sest voolud jõuavad ilusti. CAN on korras, kuid ei suhtle. K-line pidi saab aju koodi kätte, kuid see ka kõik.
Ootan pakkumisi EDC16U1 ajule.
Viimati muutis R36, 09 Jaan 2014, 19:36, muudetud 1 kord kokku.
- siLc
- Auto: Passat B7 EcoFuel
- Tänatud: 155 korda
Kas aju varuosakoodi järgi ei oleks lihtsam? Saksa ebay´st leiab sellise otsisõnaga nii 2.5 TDI kui 2.0 TDI ajusi...golfi_vend kirjutas:Ootan pakkumisi EDC16U1 ajule.
- Tänanud: 44 korda
Selle koodiga ajusid vähe ebays, 3 vist oli. Kui leiab suvalise 1.9TDI aju siis võib softi ringi visata.siLc kirjutas:Kas aju varuosakoodi järgi ei oleks lihtsam? Saksa ebay´st leiab sellise otsisõnaga nii 2.5 TDI kui 2.0 TDI ajusi...golfi_vend kirjutas:Ootan pakkumisi EDC16U1 ajule.
See pole esimene touran, mis ei käivitu.
Tean ühte veel millel oli selline anomaalia mis mingihetk ise ära kadus.
- Tänanud: 44 korda
Mismoodi ise? Hommikul ei käivitunud, õhtul käivitus?ylbik kirjutas:See pole esimene touran, mis ei käivitu.
No umbes nii jah, midagi susiti aga tulemuseta ja siis mingi hetk lihtsalt läks käima.
- Tänanud: 44 korda
See tundub levinud viga olevat. Sama asja olevat juhtunud ka golfidel. Auto lihtsalt ei käivitu ja mootori veatuled ei sütti.ylbik kirjutas:No umbes nii jah, midagi susiti aga tulemuseta ja siis mingi hetk lihtsalt läks käima.
Kui meenutada siis vist oli armatuur ka pime olnud, olin ise mõnisada km. eemal ja jagasin soovitusi.
Ei teagi mis seal täpsemalt oli, peale seda intsidenti sõitis ilusti paar kuud kuni maha müüdi, eks ilmselt ikka see aju relee viga oli.
- Tänanud: 44 korda
KORRAS!
Tõin Tartust uue aju ja kõik täpselt nii nagu vaja. Armatuuris süttisid Eelsoojendus ja mootori tuled, lisaks püsika tuli.
Immo on vaja sobitada aga see laheneb nädala pärast.
Lisaks lugesin, et vana aju võib saada töökorda tehasetestriga tarkvara uuendades.
Re: Touran ei käivitu. KORRAS!
Lihtsalt huvipärast küsin, et miks ei sobi tavaline softi kirjutav kaabel?
- Tänanud: 44 korda
Vot ei tea, mulle õpetati, et just VAS PC peab olema, tavaline flash ega BDM ei toiminud.ylbik kirjutas:Lihtsalt huvipärast küsin, et miks ei sobi tavaline softi kirjutav kaabel?
- Tänanud: 44 korda
Ise ei proovinud ja naised saunas ka ei rääkinud. Sain abi ühe sloveenia tuunija käest.ylbik kirjutas:Kas proovisid ise või naised saunas rääkisid?
- Tänanud: 44 korda
Neile, kes EDC16U1 aju seestpoolt näha tahavad:
