vw Passat b6 103 kw, 8v läheb kiirendades avarii režiimi. vagcomiga näitab et leak in air intake system.
kust viga otsima hakata?
Address 01: Engine Labels: 03G-906-021-BMM.clb
Control Module Part Number: 03G 906 021 MS HW: 028 101 271 9
Component and/or Version: R4 2,0L EDC G000AG 9390
Software Coding: 0000078
Work Shop Code: WSC 81000 205 52844
VCID: 7CF7127B3F1EBCFEC8B-8029
1 Fault Found:
008825 - Leak in Air Intake System
P2279 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 323622 km
Time Indication: 0
Date: 2016.07.15
Time: 04:00:08
Freeze Frame:
RPM: 2016 /min
Speed: 63.0 km/h
Load: 61.2 %
Voltage: 14.67 V
Bin. Bits: 00001000
Torque: 234.2 Nm
Temperature: 48.6°C
2.0 tdi läheb limpi
raix130290
raix130290
Re: 2.0 tdi läheb limpi
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3CZ6E173369 License Plate:
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Not installed.
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Not installed.
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Failed or Incomplete
Oxygen sensor heater monitoring: Failed or Incomplete
Exhaust Gas Recirculation: Failed or Incomplete
Fuel System: Passed
raix130290
