Veakoodide tähendused ja info diagnostikateenuse pakkujatest
TUUMAENN
Auto: Vw passat 3,2 4motion
Lugemata postitus Postitas TUUMAENN »
Terve! Oskab äkki keegi aidata mida peaks tegema.Autoks vw passat 3,2 4 motion 2006a DSG kastiga.
Veakood Valve for controlling clutch operating angel N373 ja 00003 control unit
Tänanud: 15 korda
Tänatud: 133 korda
Lühikesed küsimused VI
Keegi oskab seletada, mis vigadega tegemist,
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 7L0 907 401 HW: 8E0 907 401 AB
Component: 3.0L V6TDI G000AG 0110
Revision: --H02--- Serial number: VWZ3Z0D1286895
Coding: 0011775
Shop #: WSC 06325 000 00000
VCID: 683A6C2F9B7C88526D2E2D-515F
5 Faults Found:
012696 - Control Circuit for Intake Manifold Runner (Bank1)
P3198 - 002 - Implausible Signal
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 24
Reset counter: 255
Mileage: 247750 km
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Torque: 50.7 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Duty Cycle: 0.4 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 247750 km
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Torque: 50.7 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Duty Cycle: 0.4 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0546 - 000 - Short to Plus
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 247750 km
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Torque: 50.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Torque: 171.6 Nm
008200 - Intake Manifold Flap; Bank 1
P2008 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 247752 km
Time Indication: 0
Freeze Frame:
RPM: 1512 /min
Torque: 222.3 Nm
Speed: 43.7 km/h
Voltage: 13.98 V
Duty Cycle: 11.8 %
Duty Cycle: 88.8 %
Duty Cycle: 74.6 %
005445 - Throttle Valve Controller
P1545 - 002 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 247757 km
Time Indication: 0
Freeze Frame:
RPM: 1575 /min
Torque: 241.8 Nm
Speed: 53.8 km/h
Voltage: 13.91 V
Duty Cycle: 53.3 %
Bin. Bits: 000
Mass Air / Rev.:
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: GA HSG 0201
Coding: 0000065
Shop #: WSC 00757 264 00047
VCID: 3E96EA77A978E6E2F752FB-4AE9
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Subsystem 6 - Component: IRUE No Answer
Need vist tunduvad mingist juhtmekimbu lyhisest uksejuures?
8 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
01134 - Alarm Horn (H12)
000 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit - Intermittent
01462 - Anti-theft alarm ultra sonic Sensor (G209)
008 - Implausible Signal - Intermittent
Niipalju elektroonika vigu - akuga seoses kõik ok? Kui vead puhtaks lasta, ilmuvad tagasi?
Tänatud: 204 korda
Kollektorid vaja vahetada, segusiibriga probleem ja DPF temp andur küpse.
Tänanud: 15 korda
Tänatud: 133 korda
TiitRE kirjutas: 01 Sept 2018, 20:39 Niipalju elektroonika vigu - akuga seoses kõik ok? Kui vead puhtaks lasta, ilmuvad tagasi?
Mootori kaks esimest jäid alles
Tänanud: 15 korda
Tänatud: 133 korda
R36 kirjutas: 01 Sept 2018, 20:48 Kollektorid vaja vahetada, segusiibriga probleem ja DPF temp andur küpse.
Dpf olla välja lõigatud, kas siis vaja softi kirjutada veel?
Oinanahk
Auto: VW Passat Variant B6 R-Line 1.4 TSI EcoFuel 110kW DSG 2010
Lugemata postitus Postitas Oinanahk »
Hei!
2010 a Passatil (CNG) sellised koodid:
P0130 02Sensor CIrcuit Bank 1 Sensor 1
ja P0135 (ei teinud kahjuks pilti õigel ajal).
mis sisu neil on?
Aitäh ette!
One Life? Live it!
GreXRa
Auto: Passat B7 2.0TDI 103KW
Lugemata postitus Postitas GreXRa »
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication - Intermittent
01334 - Door Control Module; Rear Right (J389)
02498 - Left Low Beam Reflector Motor (V294)
007 - Short to Ground - Intermittent
02499 - Right Low Beam Reflector Motor (V295)
00233 - Sensor for Automatic Distance Control Coverage Area Blocked
003 - Mechanical Failure - Intermittent
9458449 - Cellular Antenna
B1053 11 [009] - Short to Ground
Kas Antud olukorras ei saa lihtsalt juhe ühendust autoga või on mingi viga asjadel?
GreXRa kirjutas: 06 Dets 2018, 21:34 Tere!
Distantsi sensori viga eeldab, et tegu natuke uuema autoga juba? 8)
P.S kui juhe ei saaks autoga ühendust, siis ta neid vigu ju ära ei tunnekski, siin aga konkreetsed vead leitud?
GreXRa
TiitRE kirjutas: 06 Dets 2018, 21:44
Tegu Passat b7ga. Kuidas need vead võivad väljenduda? Kõik aknad käisid ilusti ülesse alla küll jne
Intermittent = on esinenud, s.t mitte püsiv. Kas ilmuvad tagasi? Nõrga aku puhul viskab ka igasugu huvitavaid vigu.
GreXRa
Kustutasin ära ajust, panin auto käima, kinni tagasi ja siis süüde sees võtsin uuesti veakoodid. Peaksid ikka ssisse jääma?
GreXRa kirjutas: 06 Dets 2018, 23:14 Kustutasin ära ajust, panin auto käima, kinni tagasi ja siis süüde sees võtsin uuesti veakoodid. Peaksid ikka ssisse jääma?
Lasi vead ära kustutada? Seisma pole vaja jätta, saad ka kohe uuesti ju scanni teha. Intermittendi puhul oleks kena, kui vead tagasi ei ilmuks. Kuidas aku ja käivitumine muidu oli?
Aga siin foorumis on ka palju targemaid nõuandjaid... 8)
GreXRa
Seda mõtlesingi et kustutasin vead ära ja siis panin käima, kinni auto ja siis lugesin uuesti ja ikka sees. Esimese käivitusega nagu tundus et oli kergelt raskusi käima minnes, aga teine kord proovisin siis oli okei juba.
GreXRa kirjutas: 06 Dets 2018, 23:43 Seda mõtlesingi et kustutasin vead ära ja siis panin käima, kinni auto ja siis lugesin uuesti ja ikka sees. Esimese käivitusega nagu tundus et oli kergelt raskusi käima minnes, aga teine kord proovisin siis oli okei juba.
Nii. Mina teeks nii - lae aku korralikult täis, kustuta vead ja scanni uuesti. Vigade lugemisel ja kustutamisel pole vaja autot vahepeal seisata ja uuesti käivitada.
GreXRa
Antud hetkel soov autot osta ja tegin autoplatsil selle lugemise.
Kas vead kustutasid "delete all" nupuga autosc'ännist või iga moodul eraldi? Teinekord see delete all ei toimi hästi ja tuleb iga moodul käsitsi avada ja kustutada. Auto taaskäivitamine tekitab jah teinekord vigu, mis kohe ei tule, nii et see pigem mõistlik teha jah.
GreXRa
Sai vist delete alliga kustutatud jah. Eks peab uurima täpsemalt asja siis.
martvl
Telefon: +37256805878
Lugemata postitus Postitas martvl »
Nii kuna auto juba varsti 2 kuid remondis,tundub et jagu ei saada mu käsipiduri jamaga pöördun oma murega siia
Vahetatid on käsipiduri juht aju.sama koodiga mis ennist peal oli(vähemalt nii väideti )ostsin ise aju mulle antud koodi järgi..
Peale vaheyust ja kodeerimist järgnevad vead
Pole vcds tehtyd diagnost vaid miski kallima pilliga..
01424 Lateral accelaration sensor no or incorrect basic settings/adaptation
Ja
01279 longitudinal acceleration sensor no or incorrect basic settings/adaption
Põlevad eelsūūte tuli.käsipiduri tuli ja veojôukontroll
Basic settinguid pannes näitab,et parameetrid valed, kuigi õiges vahemikus..
Ja veakoodiks loeb
Brake 063 Procedure unavailable or Parameter out of range( NRC:$31)
Parking Brake 020 Procedure unavailable or parameter out of range (NRC:$31)
mr.white
Lugemata postitus Postitas mr.white »
oleks veidike abi vaja veakoodide tõlgendamisega. Nimelt mure selles, et klaasid lähevad hetkega uduseks - kohe kui kliima "auto" resiimist maha võtta. Tegin flap asendite reseti jne aga ei aidanud. Veakoodide lugemisel avastasin veel terve hulga muid vigu :shock:
Kood: Vali kõik
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 NK    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  9972
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 50156 136 52721
   VCID: 75EBFF0D1CDA171
1 Fault Found:
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 6
                    Mileage: 330419 km
                    Time Indication: 0
                    Date: 2020.01.30
                    Time: 14:34:00
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    (no units): 16.0
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 BC    HW: 3C0 907 044 BC
   Component: ClimatronicPQ46 112 0606
   Revision: 00112021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 63CFB155A24E991
2 Faults Found:
XXXXXXXXXXX siin vist päästab vaid detailide vahetus? XXXXXXXXXXXXXXXX
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 132
                    Reset counter: 194
                    Mileage: 329441 km
                    Time Indication: 0
                    Date: 2019.12.15
                    Time: 16:27:37
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 330331 km
                    Time Indication: 0
                    Date: 2020.01.25
                    Time: 12:40:40
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AG    HW: 3C0 937 049 AG
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006786929
   Coding: E38A8F0700041A00470A00000F000000000F5D435C0001
   Shop #: WSC 05311 000 00000
   VCID: 6ED9D061798C249
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 120207 003  0205
   Coding: 00046997
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     180708 046  0204
   Coding: 00208933
   Shop #: WSC 05311
2 Faults Found:
01800 - Light Switch (E1)  XXXXXXXXXXX seda tean kus viga, üks lüliti realselt ka ei tööta XXXXXXXXXXXXXXXXXXXXXXXXXXX
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 218
                    Mileage: 330094 km
                    Time Indication: 0
                    Date: 2020.01.16
                    Time: 13:09:00
             Freeze Frame:
                        OFF
                    Voltage: 12.20 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 41
                    Reset counter: 234
                    Mileage: 330341 km
                    Time Indication: 0
                    Date: 2020.01.25
                    Time: 14:31:00
             Freeze Frame:
                        OFF
                    Voltage: 12.95 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 80093 222 71269
   VCID: E1C33B5D38520B1
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 219935 km
                    Time Indication: 0
                    Date: 2014.12.01
                    Time: 01:23:35
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0048
   Revision: 00007000    Serial number: 0700C07305050E
   Coding: 7DFD8C44C22002
   Shop #: WSC 27354 001 1048576
   VCID: 2143FB5DF8D2CB1
4 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 228
                    Mileage: 330051 km
                    Time Indication: 0
                    Date: 2020.01.12
                    Time: 11:53:04
01300 - Control Module for Navigation with CD-Rom (J401)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 228
                    Mileage: 330051 km
                    Time Indication: 0
                    Date: 2020.01.12
                    Time: 11:53:07
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 228
                    Mileage: 330051 km
                    Time Indication: 0
                    Date: 2020.01.12
                    Time: 11:53:07
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 228
                    Mileage: 330341 km
                    Time Indication: 0
                    Date: 2020.01.25
                    Time: 14:31:15
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    KSG PQ46 ELV 042 0472
   Revision: 00042000    Serial number: VWZCZ000000000
   Coding: 0091020051030E763004941570084F0B607C00
   VCID: 3973333D7042B31
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 234
                    Mileage: 330341 km
                    Time Indication: 0
                    Date: 2020.01.25
                    Time: 14:35:47
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0000011
   Shop #: WSC 33316 133 69394
   VCID: 244DF249E7C0DE9
2 Faults Found:
XXXXXXXXXXXX KAS tähendab uusi mootoreid? Kuigi kasutasin just pool tundi tagasi parkpidureid kallaku peal ja auto jooksu ei pannud XXXXXXXXXXX
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 330048 km
                    Time Indication: 0
                    Date: 2020.01.12
                    Time: 11:36:19
             Freeze Frame:
                    Voltage: 8.07 V
                    Count: 205
02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 330048 km
                    Time Indication: 0
                    Date: 2020.01.12
                    Time: 11:36:19
             Freeze Frame:
                    Voltage: 8.07 V
                    Count: 204
Tänanud: 331 korda
Tänatud: 187 korda
Need on peale veakoodide kustutamist tekkinud vead?
Ja flap mootoreid kuidagi remontida ei saa, aitab ainult vahetus ja tk hind u. 50-60€
Viimati muutis etnies858, 30 Jaan 2020, 23:01, muudetud 1 kord kokku.
mr.white kirjutas: 30 Jaan 2020, 22:59 Tere,
Suurem osa vigu on mitte pidevad...aku pole vahepeal liialt tühi olnud? Kustuta ära ja sõida natuke ja vaata uuesti.
Tänatud: 604 korda
etnies858 kirjutas: 30 Jaan 2020, 23:00 Need on peale veakoodide kustutamist tekkinud vead?
Tegelikult saab remontida. Seal on sees ainult potensiomeeter ja mikromootor.
Oomipoest saab uue poteka (maksavad üldiselt sentides, max mõni eur). Mootori saab lahti võtta, puhastada, määrida ja töötab jälle.
Kunagise töökaaslase A4-l tegime nii. Algul vahetasime ainult potekad ära, läks paremaks, aga mitte heaks. Peale mootorite puhastust toimisid nagu uued.
VWjuht
Telefon: 59079743
Auto: VW Golf III, Golf IV, Golf VI GTI
Lugemata postitus Postitas VWjuht »
Tervist, oleks tarvis veidi abi veakoodi eemaldamisel. Alustuseks, autoks on Golf VI GTI 2010 2.0 147kW USA'st siis ja veakoodiks P2570 - Catalyst Temperature Sensor High Input. aktiivselt ees. Tegemist on USAs nõutava G611 anduri veaga, mis asub radiaatori küljes ja antud andurit enam ei toodeta eraldi nagu Møllerist teada sain. Kas leidub siin keegi kes oskab aidata ehk veakoodi eemaldamisega? Asun ise Tallinnas.
Viimati muutis VWjuht, 25 Veebr 2020, 08:59, muudetud 1 kord kokku.
Volkswagen, Das Auto
tlauri
Tänatud: 17 korda
"Aitamine" raha ette ikka saab. Samas teades, et igaüks seda teha ei oska ega suuda siis see paneb kogu aitamise asjandusele mõnusa hinnalipiku. Mõttena parem otsi ebayst, dalys vmi teine radikas, kus see G611 küljes.
