Hei mure vw passat 2001 b5.5 1,9 74kw diisliga
konn1
Telefon: 53038827
Auto: Maaža
Lugemata postitus Postitas konn1 »
Tervitus volksupere,tekkis mure tsirka kolm nädalat tagasi juba soomes,et sai vuratud mööda kiirteed helsinki poole aga hyvinkääl jäi seisma mootor(möödasoidul) eriti hull :shock:.Ja enam käima ei lähe,ning ei vea starterit kah ringi,ainult piniseb mingi klappike vms ja köik.Aku sai täis laetud,proovitud teise autopealt voolu anda aga ei miskit,seisab nukkralt autoremondi platsipeal ja ootab millal keegi huvi tunneks,ning tegeleks temaga.Sai tehtud diagnostika teeääres ja panen siia diagnostika probleemide koodid kah ules,ning ehk on möni hea idee kellelgi?
Probleemi koodid
1 DTC code System name/DTC content DTC status
2 02-Transmission Control Module
3 00529 No speed information Passive/Sporadic
4 08-Air Conditioning
5 00603 Footwell/defroster flap motor Passive/Sporadic
6 01272 Central air flap motor Passive/Sporadic
7 01274 Oil Pressure Actuator Passive/Sporadic
8 00532 Supply voltage - Signal too low Passive/Sporadic
9 00792 A/C pressure switch Passive/Sporadic
10 15-Airbag
11 00532 Supply voltage - Signal too low Passive/Sporadic
12 17-Dash Board
13 01336 Combination Comfort databus - In single wire mode Passive/Sporadic
14 00476 Fuel pump control module - No communication Active/static
15 19-Gateway
16 01336 Combination Comfort databus - In single wire mode Passive/Sporadic
17 00476 Fuel pump control module - No communication Active/static
18 01333 Left rear door control module - No communication Passive/Sporadic
19 25-Immobilizer
20 01336 Combination Comfort databus - In single wire mode Passive/Sporadic
21 00476 Fuel pump control module - No communication Active/static
22 46-Central Module Comfort System
23 01336 Combination Comfort databus - In single wire mode Active/static
24 01333 Left rear door control module - No communication Passive/Sporadic
25 00933 Motor for window lift, frt. pass. side - no adjustment or
incorrect adjustment
Active/static
Vanad volkarid ei sure never ever vaind lähevad ikka madalamaks
Tänanud: 98 korda
Tänatud: 193 korda
Sel tugeva voolu kaitsmed on kapoti all kuskil - vaata üle.
konn1
Telefon: 53038827
Auto: Maaža
Ja vahepeal tegi kah sellist tsirkust nagu selles videos,aga peale kÛttefiltri vahetust ei olnud enam probleemi.
konn1
Telefon: 53038827
Auto: Maaža
Läks aega aga sain täna kõne autoremondikojast ja öeldi,et mootor enam ringi ei käi.Eks tuleb transada eesti nüüd auto ja lahti lammutama hakkata aga hea uudis see pole.
Ja uuriks mis hinda jäävad 1,9 96kw mootorid?
Tänanud: 824 korda
Tänatud: 123 korda
konn1 kirjutas: 13 Dets 2018, 17:25 Läks aega aga sain täna kõne autoremondikojast ja öeldi,et mootor enam ringi ei käi.Eks tuleb transada eesti nüüd auto ja lahti lammutama hakkata aga hea uudis see pole.
Kokkuvõttes odavam osta terve töötav 96kw mootoriga auto!
Enda auto kui saad siis võid ise võta juppideks ja saad selle auto eest rohkem kui lammutus pakub.
Või kui leiad kehvas korras aga hea 96kw mootoriga masina siis saad enda masinalt mingeid vajaminevaid juppe ringi tõsta.
konn1
Telefon: 53038827
Auto: Maaža
Ise garaažis nokkitsen korda igastahes ja kere on mul pm roostevaba passatil.Õnneks teine auto mul varuks olemas,mitte passat aga liigub siiski.Aga hoian kursis teid ja annan teada,et mis tükki ma saan süüdlaseks tembeldada lõppuks.
Kui vaja saan puksiirteenusega aidata.
konn1
Telefon: 53038827
Auto: Maaža
Suured tänud aga sain uhke tulede ja numbritega konna renditud.Hoian teid kursis ja ehk teen teemagi siia vw klubisse oma kurvamootoriga passatist.
Mootorit vöite kyll pakkuda kas 74 voi 96kw
Lööge mind või maha, aga mina sellise eluka elustamisel pointi ei näe. Transa teisest riigist Eesti (topelt laevapiletid+konna rent, konn tuli/tuleb ju koduriiki tagasi saada, tasuta seda vist laeva ei lasta), otsida mingi kasutuskõlblik mootor, remont..... Kas see kõik mitte turuhinnale pika puuga ei lajata?
konn1
Telefon: 53038827
Auto: Maaža
No olen siin mootorit uurinud ja 200eurkaga saab kätte blokki koos kaanega(vast annab maha kah tingida),üljäänud pudinad endal olemas,ning toimetavad.Ma muidu ei hakkaks taastama aga kere tiptop.Soome ajalooga masin ja hooldusraamat olemas sellekohta ja annan täpsemat infi selle transamise kohta kui see trall homme läbi on.
Mis sa siis ise teeks jussike teeks? Juppideks?
Kui oleks aega tegeleda, siis juppideks, aga kuna vajab transat üle lahe, siis võtaks arvelt maha ja paneks Soomes oksjonile, võib päris mitusada € saada.
konn1
Telefon: 53038827
Auto: Maaža
Juba ilusti kenasti eestis passat
Purjekas
Auto: Passat B5.5 Variant 2002 1.9TDI 74kw ATM, Golf IV 2001 1.6 77kw
Tänanud: 6 korda
Lugemata postitus Postitas Purjekas »
konn1 kirjutas: 18 Dets 2018, 19:11 Juba ilusti kenasti eestis passat
palju midagi maksis, et üle lombi tuua?
konn1
Telefon: 53038827
Auto: Maaža
No 2015 mitsubishi pajeroga sai toodud ja diislit läks pm terve paak ära(80 littra diislit),laevapiletid edasi tagasi(85 rutsi) ja konna rent 25 rutsi pluss söök ja jook aga 250 euroga võib arvestada ümmarguselt.Puksiiriga oleks olnud 500 ja peale eurot
500+ puksiir tundub natuke ulme. Kindlasti oleks see number ikka väiksem tulnud, kui näiteks minult oleks küsinud.
konn1
Telefon: 53038827
Auto: Maaža
Minujaoks oli kah 500 ulme aga puksiirimees ütles soomes mulle,et alla 500 ta ei hakka liigutamagi end eesti poole.Kahju,et sõber ega ma ise kah ei tohi vedada kaheteljelist puksiirhaagist.Sest see oleks kah suht soodne tulnud ja mugavam kui laia konnaga jebida ma usun :D
Minu käest saab ka ainult puksiiri rentida. 3,5t, ehk B kat lubadega.
konn1
Telefon: 53038827
Auto: Maaža
Toimetad tallinnas?
konn1
Telefon: 53038827
Auto: Maaža
Jee asjad arenevad ja uuel kuul pasteet korras
Viimati muutis konn1, 09 Mär 2019, 23:24, muudetud 1 kord kokku.
konn1
Telefon: 53038827
Auto: Maaža
On teinud keegi volksuperest Atd pealt swappi asz moto peale?
