Address 01: Engine (CEX) Labels: None
Part No SW: 3D0 907 401 H HW: 3D0 907 401 D
Component: 3.0TDI EDC17G000AG 0020
Revision: --H05--- Serial number: VWX3Z0K1933033
Coding: 0406002C191F0160
Shop #: WSC 00191 264 15243
VCID: 2411EAD3B2CCCB3B173-5184
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H35 0047
Coding: 0008356
Shop #: WSC 01065 000 00000
VCID: 6B83C1EF1F92C443969-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H23072 Serial number: VWX3Z0K1933033
Coding: 0004328
VCID: 2A0D04EBD0B81D4B2DF-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
01042 - Control Module; Not Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 0
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
00171 - Key 1 not learned
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 0
Reset counter: 74
Time Indication: 0
Date: 2018.10.25
Time: 18:41:02
01176 - Key
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2018.11.08
Time: 10:10:10
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0035
Revision: ABH34001 Serial number: VWZ6Z7L0072027
Shop #: WSC 00000 000 00000
VCID: 6393A9CFF7128C032E9-8036
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 M
Component: Climatronic D1 2039
Coding: 0000001
VCID: 2809FEE3CEB42F5B3BB-807C
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 P HW: 3D0 937 049 P
Component: J519 7600
Revision: -4006--- Serial number: --------------
Coding: 618C0000EB311DC25502770000000000
VCID: 372B2D9F130AB0A3A21-8062
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 F
Component: 0S Airbag 8.4E+ H13 1155
Coding: 0012371
VCID: 2615F0DBC4A0392B097-8072
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000011
VCID: 47CB5D5F63EAC023D21-8012
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No SW: 3D0 920 886 C HW: 3D0 920 886 C
Component: J285 KOMBI-INST. 1521
Revision: KPH06V05
Coding: 0039101
Shop #: WSC 80093 222 69422
VCID: 2B0301EFDF020443D69-807E
Address 18: Aux. Heat Labels: None
Part No: 3D0 815 005 AP
Component: J737__Standheizung 4405
Revision: 00084000 Serial number: 09020869A00000
VCID: 6B83C1EF1F82C443969-803E
2 Faults Found:
01414 - Combustion-Air Blower (V6)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 9
Reset counter: 255
Mileage: 179756 km
Time Indication: 0
Date: 2017.11.01
Time: 21:28:40
Freeze Frame:
Start
Temperature: 2.0°C
Voltage: 13.60 V
Temperature: 1.0°C
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180081 km
Time Indication: 0
Date: 2017.11.21
Time: 08:28:10
Freeze Frame:
Malfunction
Temperature: 13.0°C
Voltage: 13.87 V
Temperature: 1.0°C
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3D0 920 886 C
Component: J533 GW-K-CAN TP20 1521
Coding: 7FF2F3AC33011002
VCID: 70B9D68336A4279BA3B-8024
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005521
Shop #: WSC 64808 001 1048576
VCID: 270BFDDFC3AA2023321-8072
1 Fault Found:
01583 - Leak in System Detected
000 - - - Intermittent
Address 37: Navigation (J0506) Labels:. 3D0-035-680.clb
Part No SW: 3D0 035 680 B HW: 3D0 035 680 B
Component: RNS-MID H34 1230
Revision: AB001001 Serial number: VWZ6Z7L0072027
Coding: 020100020000002000
VCID: 1F1BE53F97BAE8E34A1-804A
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 F
Component: Dachmodul 0903
Coding: 0012345
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 M
Component: 6Z HSG 8133
Coding: 0000040
VCID: 3A2D34AB2048ADCB5DF-4B00
Subsystem 1 - Part No: 3D1 959 701 G
Component: Tuersteuergeraet FS 0202
Subsystem 2 - Part No: 3D1 959 702 G
Component: Tuersteuergeraet BF 0202
Subsystem 3 - Part No: 3D0 959 703 G
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 3D0 959 704 G
Component: Tuersteuergeraet HR 0202
Subsystem 5 - Part No: 3D0 909 610 F
Component: 3P HDSG 2630
4 Faults Found:
00984 - Left Tail Light (M4)
009 - Open or Short to Ground - Intermittent
00985 - Right Tail Light (M2)
00987 - Lamp for Brake Light; Left (M9)
00988 - Lamp for Brake Light; Right (M10)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 3D0 035 465 C HW: 3D0 035 465 C
Component: 08K Audioverst. 0120
Revision: 00005000 Serial number: 00000000240248
VCID: 211FE3C7ADCEDE137C5-8074
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Address 52: Door Elect, Pass.
Cannot be reached
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 012A00000B000200
Shop #: WSC 01065 000 00043
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 372B2D9F1FCAB0A3A21-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No: 3D0 941 329 A Labels: 3D0-941-329.CLB
Right_headlamp_power_output_stage:
Subsystem 2 - Part No: 3D0 941 329 A Labels: 3D0-941-329.CLB
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 195945 km
Date: 2019.02.13
Time: 19:09:35
Address 56: Radio (J0506) Labels:. 3D0-035-680.clb
Address 62: Door, Rear Left
Cannot be reached
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V2.clb
Part No: 3D1 955 119 B
Component: Front Wiper 3501
Coding: 0015733
Shop #: WSC 01065 000 376832
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 E
Component: Batteriemanagement 2800
VCID: 2517F7D7B9A6323300D-8070
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 E
Component: 10 Einparkhilfe 1107
VCID: 2C0102F3DA4C037BDF3-8078
End----------(Elapsed Time: 03:19, VBatt start/end: 12.1V/12.1V)-----------
Cannot be reached
Coding: 0008356
Coding: 0004328
Component: ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 0
Reset counter: 74
Time Indication: 0
Date: 2018.10.25
Time: 18:41:02
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2018.11.08
Time: 10:10:10
Coding: 0000001
Coding: 0012371
Coding: 0000011
Revision: KPH06V05
Coding: 0039101
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 255
Mileage: 179756 km
Time Indication: 0
Date: 2017.11.01
Time: 21:28:40
Freeze Frame:
Start
Temperature: 2.0°C
Voltage: 13.60 V
Temperature: 1.0°C
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180081 km
Time Indication: 0
Date: 2017.11.21
Time: 08:28:10
Freeze Frame:
Malfunction
Temperature: 13.0°C
Voltage: 13.87 V
Temperature: 1.0°C
Coding: 0005521
1 Fault Found:
Coding: 0012345
Cannot be reached
Coding: 0000040
4 Faults Found:
1 Fault Found:
011 - Open Circuit
Cannot be reached
1 Fault Found:
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 195945 km
Date: 2019.02.13
Time: 19:09:35
Cannot be reached
Coding: 0015733
Cannot be reached
- IMG_20200729_200637v.jpg (213.59 KiB) Vaadatud 2771 korda
- IMG_20200729_200641v.jpg (208.58 KiB) Vaadatud 2771 korda
