Golf 5 ei käivitu
veiks23
Golf 5 ei käivitu
Lugemata postitus Postitas veiks23 »
Tere.
Autoks golf 5 1.9 77kw diisel automaat mis ei käivitu.
VCDS veakoodid sellised
Kood: Vali kõik
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ5B104904   Mileage: 247810km-153981miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 DF    HW: 028 101 190 1
   Component: R4 1,9L EDC 0000AG  6177
   Revision: 12345678    Serial number: VWZ7Z0E1506653
   Coding: 0000078
   Shop #: WSC 80093 222 69422
   VCID: 6ADC19EA45E4A91157-803E
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         081 1117
   Revision: 04608010    Serial number: 00000705301077
   Coding: 0000020
   Shop #: WSC 44551 111 44551
   VCID: 234234CEE24EB859D4-8076
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8A98BE6EE6FCB9D0-806A
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Q0 907 044 AJ    HW: 1Q0 907 044 AJ
   Component: ClimatronicPQ35 131 0405
   Revision: 00131023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 75E63A961C5A76E9CA-8020
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001474241
   Coding: 03898F0600041000001400001400000000087F075C
   Shop #: WSC 01357 011 00200
   VCID: 3A7CE9AA75C4D991E7-806E
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 01357
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 07 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD054XA2
   Coding: 0012343
   Shop #: WSC 00046 412 16384
   VCID: 2C50DFF28F90772165-8078
   Subsystem 1 - Serial number: 6332MSME085B5C0EQ
   Subsystem 2 - Serial number: 6342MSME0822415C6
   Subsystem 3 - Serial number: 6351HSME060C043C4
   Subsystem 4 - Serial number: 6361HSME061D4D2FM
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0010012
   Shop #: WSC 00046 412 1007616
   VCID: 3566FA965CDA36E90A-8060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 861 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0001103
   Shop #: WSC 14557 222 69422
   VCID: 285823E29B685B0181-807C
1 Fault Found:
00003 - Control Module
            014 - Defective
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010512508EA
   Coding: 3F3F0B40070002
   Shop #: WSC 00046 412 1679360
   VCID: 295E26E6806262099E-807C
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0153
   Coding: 0000052
   Shop #: WSC 00046 412 1695744
   VCID: 3068CB82A3B813C159-8064
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404084F01E010
   VCID: 7BF22CAE3A7E2099BC-802E
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316ECE86A8B21AC956-8064
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 R
   Component: Radio GR0       019 0023
   Revision: 0001905S    Serial number: VWZ2Z2F1682731
   Coding: 0020200
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D56D2F6B48A7E2972-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 02:09)--------------------------
Tänatud: 155 korda
Golf 5 ei käivitu
Mida teeb ja mida ei tee? Käima läheb aga suretab kohe välja? Kellaploki "defektiivne" olek seda viitab...
veiks23
Golf 5 ei käivitu
Tühjalt ketrab mootorid. Nagu siis kui kütus on otsa saanud
