2008 Passat B6 veakoodide seletus
Vincento
- Auto: 2025 VW Tayron Life 1.5 l eHybrid GPF
- Tänanud: 5 korda
Palun abi veakoodide lahendamisel
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 G 4369
Revision: --H52--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 62219 136 181636
VCID: 74FECC838EBBDAA20BE82A5-8020
2 Faults Found:
005714 - Please check DTC Memory of Transmission Controller
P1652 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 105
Reset counter: 40
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
RPM: 1568 /min
Torque: 72.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 10.73 V
Bin. Bits: 00000001
Bin. Bits: 00000000
004705 - PD Unit Injector: Cylinder 1 (N240)
P1261 - 006 - Regulation Range Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 26
Mileage: 237154 km
Time Indication: 0
Date: 2017.02.22
Time: 05:41:08
Freeze Frame:
RPM: 1856 /min
Torque: 120.0 Nm
Speed: 94.0 km/h
81.90 %
Text: 5.125 uF
Text: 15.50 mJ
Text: 11 mJ
Speed: 211.2 km/h
Readiness: N/A
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 050 C HW: 02E 927 770 AE
Component: GSG DSG 081 1403
Revision: 04708010 Serial number: 00000711150571
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1232AA1B946F7492B9D41CD-8046
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 1
Mileage: 237430 km
Time Indication: 0
Date: 2017.02.28
Time: 05:56:03
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776610194
Coding: 0002333
Shop #: WSC 05311 000 00000
VCID: 1F54F32F57BD29FA065A8D1-804A
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 79
Reset counter: 173
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
Speed: 49.0 km/h
Hex Value: 0x013B
Voltage: 14.50 V
Bin. Bits: 00011111
Count: 30
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CS HW: 3C0 907 044 CS
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 67
Reset counter: 216
Mileage: 236935 km
Time Indication: 0
Date: 2017.02.17
Time: 17:09:52
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000264044
Coding: 0000057
VCID: 2940EDF719F9D74A68FE139-807C
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11111101
Fault Priority: 3
Fault Frequency: 79
Reset counter: 175
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
Voltage: 14.00 V
Count: 106
Speed: 48.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Tänud ette
Coding: 0000078
2 Faults Found:
P1652 - 008 -
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
RPM: 1568 /min
Torque: 72.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 10.73 V
Bin. Bits: 00000001
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 26
Mileage: 237154 km
Time Indication: 0
Date: 2017.02.22
Time: 05:41:08
Freeze Frame:
RPM: 1856 /min
Torque: 120.0 Nm
Speed: 94.0 km/h
81.90 %
Text: 5.125 uF
Text: 15.50 mJ
Text: 11 mJ
Speed: 211.2 km/h
Readiness: N/A
Coding: 0000020
1 Fault Found:
P1847 - 000 -
Freeze Frame:
Fault Priority: 0
Reset counter: 1
Mileage: 237430 km
Time Indication: 0
Date: 2017.02.28
Time: 05:56:03
Coding: 0002333
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 79
Reset counter: 173
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
Speed: 49.0 km/h
Hex Value: 0x013B
Voltage: 14.50 V
Bin. Bits: 00011111
Count: 30
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 67
Reset counter: 216
Mileage: 236935 km
Time Indication: 0
Date: 2017.02.17
Time: 17:09:52
Coding: 0000057
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 79
Reset counter: 175
Mileage: 236995 km
Time Indication: 0
Date: 2017.02.18
Time: 09:54:51
Freeze Frame:
Voltage: 14.00 V
Count: 106
Speed: 48.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Tänud ette
Re: 2008 Passat B6 veakoodide seletus
Esimese silindri pihusti on ilmselt õhtul, väljapool lubatud vahemikku näit. Viimase kontrollimiseks oleks pidanud ka vastavad näidud ette võtma, mitte lihtsalt veakoode lugema.
Tagumine vasak ABS andur on surnud
- siLc
- Auto: Passat B7 EcoFuel
- Tänatud: 155 korda
See tähendab, et juhi salongipoole temperatuuri reguleerimise klapi mootor arvab, et sel on midagi viga. Kui kaabel olemas, vaata mis kumbagi poole õhuteede temperatuurideks näitab. Kui mõlema poole temperatuurid samaks määratud ja vasakul pool on erinevus, siis küllap klapimootor ikka vahetust vajab.Vincento kirjutas:Mis on 01809 - Actuating Motor for Temperature Flap; Left (V158)?
AndreIlv
- Telefon: 55567413
- Auto: Passat b6 2008
http://wiki.ross-tech.com/wiki/index.php/01321
Kas keegi on sellise teemaga kokku puutunud?
Lõi algul parking brakes ja airbagi tule põlema, seejärel lükkasin VCDS'i taha ja üritasin viga kustutada aga kustus ainult piduri tuli, airbagi tuli jäi põlema..
Vincento
- Tänanud: 5 korda
Kaabel olemas, aga kuidas seda kõike vaadata saaks?siLc kirjutas:See tähendab, et juhi salongipoole temperatuuri reguleerimise klapi mootor arvab, et sel on midagi viga. Kui kaabel olemas, vaata mis kumbagi poole õhuteede temperatuurideks näitab. Kui mõlema poole temperatuurid samaks määratud ja vasakul pool on erinevus, siis küllap klapimootor ikka vahetust vajab.Vincento kirjutas:Mis on 01809 - Actuating Motor for Temperature Flap; Left (V158)?
kapten
- Auto: B5.5 1.9 130, A4 1.9 66kw
Lähed hvac, measure blocks ja sealt tuleb kõik asendid ja temperatuurid
