Race.Fi: Product topic
Ettevõtete sooduspakkumised ja teenused Volkswageni Klubi liikmetele.
Moderaator: silverpik
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 01 Mär 2019, 10:33
Rota wheels now in our webshop!
This week, Rota wheels was added in our webshop with product descriptions and model specific pictures. Rota is one of the leading brands in the market and you can find just the right wheels almost for any car.
Rotas wheel range covers a wide range of rims, basic 5-spoke models or more rigid models designed especially for off-road use. Rota alloy wheels are available in different bolt patterns, colors, offsets and widths. Spigot rings, center caps and nuts/bolts are always included in the shipment for free.
Yesterday, the wheels selector was released which make searching the wheels much easier, especially if you have bolt pattern, offset and/or width in mind. With wheel selector its possible to check only with wheel brand, but because of the large amount of wheels in the webshop, filtering for example with bolt pattern can be quite smart. The wheel selector is now in beta stage, but will be announced officially in no time - we recommend testing!
All Rota alloy wheels from here:
»» Race.fi: Rota alloy wheels
Have a great weekend!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 08 Mär 2019, 15:15
Wheel selector is now officially out!
The wheel selector is now officially available from our webshop, which makes it easy to find the correct wheels. Just select the desired diameter, pcd, width and/or offset and it will show all the wheels available with chosen specs.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know the specs. Of course its possible to check the wheels like before from articles or brands (its also possible with the wheel selector) - its your choice!
A lot of wheels and accesories (bolts/nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel amount doubled to the previous one. Spigot rings for the center bore always comes with both wheel brands and with Rota wheels, nuts or bolts are also delivered in the package. After a week of testing, the wheel selector is officially announced, now its time to get some wheels :)
Wheel selector can be found from here:
»» Race.fi: Wheel selector
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 11 Mär 2019, 13:45
Davies Craig electric water pumps in stock
We just got a nice batch of Davies Craig electric water pumps more in stock. We took more especially 150l/min and 115l/min models.
With Davies Craig electric water pump you can get more power and trust in the cooling system, its possible to use it with the original water pump as a booster or use only the electric pump, either way is fine! There is pumps available between 15-150l/min, smallest ones are with nylon body and biggest models with more durable aluminium body, which is actually a really great thing in bigger flowing rates.
Its possible to buy only the water pump it self or as a set which includes the controller. With controller its you can adjust the water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and as said, we got a new batch of these in this morning.
Davies Craig water pumps in our webshop:
»» Davies Craig electric water pumps
Have a great day!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 12 Mär 2019, 16:24
Suspension to good shape with a coilover kit
With D2, Eibach and H&R adjustable suspension kit you will get the suspension in shape. We can deliver all the kits fast and most popular models we keep usually in our own stock.
All the three brands has a suitable suspension kit for most common and not so common cars, for example D2 coilover kits has a stiffness adjustment with height adjustment which makes it easy to make the kit perfect for any conditions. Eibach Pro-street S kits are excellent choices especially for street use when you need a height adjustable kit which is also very comfortable.
H&R Twintube and Monotube suspension kits has almost same adjust specs, but Monotube has a different shock absorber type (upside-down) which makes it great also for race use. H&R Twintube is great mainly for street use and Monotube for race use (it also works great in a street car as a compromise).
Adjustable suspension kits in our webshop:
»» Race.fi: D2 coilover kits
»» Race.fi: Eibach coilover kits
»» Race.fi: H&R twintube coilover kits
»» Race.fi: H&R monotube coilover kits
Have a great day!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 14 Mär 2019, 16:10
Eibach spacers for coming springs
Eibach spacers makes the car look and feel much better with reasonable price. Widening the track makes the car more stable and it also gives much smoother look. Some of the most popular spacers and bolts/nuts are in our own stock.
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course its possible to ask from us - thats why we are here. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers, they are listed separately in our webshop.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway. Some of the spacer models are in our or in our suppliers stock and we always try to keep the delivery times fast as possible - for example we offer express shipping from Eibach, which is usually only a few working days (in finland) to you door / nearest pickup point.
Eibach spacers in our webshopt:
»» Eibach spacers
Eibach bolts, studs and nuts for spacers from here:
»» Eibach studs
»» Eibach bolts
»» Eibach nuts
»» Japan Racing wheel bolts and nuts
Have a great day!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 15 Mär 2019, 11:13
Ultralite and XXR wheels in webshop
We have listed all the most popular wheels which are also available in our webshop from both brands. Wheels travels very quickly from the factory and a set of spigot rings are also included for mounting.
The range of Ultralite and XXR covers lots of different type of wheels, for example a 6 and 10-spoke models. There are several color options as well as different bolt patterns, offsets and widths, which you can choose by yourself. Both wheels brands are also supplied with spigot rings, making the installation much easier and safer.
The wheel selector was released last week and it is now running at full power, just choose the correct diameter, width, bolt pattern and/or offset - thats it! Wheels selector also works with XXR and Ultralite brands, so go and find the correct ones ;)
XXR and Ultralite in webshop:
»» Race.fi: XXR wheels
»» Race.fi: Ultralite wheels
Both wheel brands are also in wheel selector:
»» Race.fi: wheel selector
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 22 Mär 2019, 12:17
Bilstein suspension kits and shock absorbers from us
From us, you will find also Bilstein B14/B16 suspension kits and B8 shock absorbers. We have listed few most popular models in our webshop and you can ask suitable kit for your car from our sales.
In this week, we listed few Bilstein B14/B16 adjustable suspension kits and also a couple Bilstein B8 sport shock absorbers. There are only couple of kits available in our webshop, but they are listed mainly to give approx prices and availabilites.
Bilstein B8 shock absorbers are little bit shorter that OEM shocks, so they are excellent for example with Eibach Pro-kit or Sportline lowering springs. Bilstein B14 and B16 kits are adjustable, lowering is between 30-50mm - B16 kits has also a 10 step damping adjustment for compression and rebound (biggest difference to B14 kit). Offer for Bilstein B14/B16 or B8 shocks can be asked from our sales, for example trough spare parts inquiry.
Bilstein suspension kits and shock absorbers in our webshop:
»» Race.fi: Bilstein coilover kits
»» Race.fi: Bilstein shock absorbers
Spare parts inquiry can be found here:
»» Race.fi: Spare parts inquiry
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 05 Apr 2019, 14:09
Model specific suspension listing
Finding the correct suspension parts is now easier than ever! Just select your car's make, series and model, and the shop will show you all the model-specific parts available for it.
The suspension search shows you all the model-specific kits in one view. Whether it's D2 coilovers, Eibach B12 Pro-Kits or B12 sportline suspension kits, or Eibach Pro-kit and Sportine lowering springs, they're all there.
The model-specific listings make things quicker, and you see everything that's model-specific and available at a single glance.
You can also narrow down the lists with the product brand and go deeper to just springs or coilovers. The shop also has several universal parts in the traditional product categories, like adjustable endlinks and coilover helper springs.
Check out the model-specific suspension listings here:
»» Race.fi: Model-specific suspension kit listings
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 12 Apr 2019, 13:20
Correct rims easily through wheel selector
Wheel selector helps a lot to find correct wheels. Just choose diameter, width, pcs and/or offset. In addition, the rims can also be filtered with different wheel brands.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know the details. Of course its possible to check the wheels like before from articles or brands.
A lot of wheels and accessories (bolts and nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel amount doubled to the previous one. Spigot rings for the center bore always comes with all our wheel brands and with Rota wheels, nuts or bolts are also delivered in the package. Usually all the wheels are in european stock, so the delivery time has been under a week in best cases.
Click the banner or this link:
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 26 Apr 2019, 12:55
Super offer: All Eibach products -10%
Lets put Eibach products in -10% discont for the next week. Probably one of the leading spring manufacturers, Eibach is a certain choice for lowering springs, shocks and kits. Eibach also makes high quality wheel spacers and sway bar kits.
Eibach Pro-kit and Sportline lowering springs
Pro-kit and Sportline lowering springs offer superior quality and ride comfort. They are also an OE choice of many factory sports kits from Audi and BMW. Pro-Kits offer drops of around 30mm, and Sportline kits 40 to 50mm.
»» Pro-kit lowering springs
»» Sportline lowering springs
Eibach Pro-kit and Sportline B12 suspension kits
The B12 kits come with Eibach springs and Bilstein B8 dampers which offer firm damping and are designed for lower springs. Most models also have an upside-down design for increased rigidity. Most customers change cars from time to time, and this is a kit many get for their new car as well. That's about as high as customer satisfaction can get ;)
»» Eibach Pro-kit B12 suspension kits
»» Eibach Sportline B12 suspension kits
Eibach Pro-street S coilovers
Eibach Pro-street S coilovers offer a very sporty driveability and a stepless height adjustment, still maintaining a lot of comfort. Offering drops of 20 to 70mm, the Pro-Street S coilovers are a choice of a gentleman seeking the perfect stance.
»» Pro-Street S coilover kits
Eibach Anti-Roll-Kit sway bar kits
A sway bar kit is the overlooked way to increase stability in cornering without sacrificing any of the comfort. Stiffer roll bars keep the car level in corners, and at the same time allow for softer and more comfy springs - or overall better track performance of course - its your choice!
»» Anti-Roll-kit roll bar kits
Eibach Pro-spacers
Eibach Pro-Spacers are an excellent pair to go with Pro-Kit or Sportline lowering springs and when the wheel looks lack "it". Spacers will bring out the wheels by the amount of their thickness from both sides. Spacers can be found with specs (pcd, center bore) or with car model, depends does the listing recognize your vechile.
»» Eibach Pro-spacers
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 07 Juun 2019, 13:11
Weekie: Davies Craig electric water pumps
Lets put the Davies Craig electric water pumps on discount in our weekly offer. Now its a great opportunity to get more cooling for the hot summer, most popular water pump models are in our own stock and we order more at least every week.
With Davies Craig electric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
Invoice options at race.fi:
Collector: up to 60 days of intrerest fee free payment time. 2.95€ invoice fee. Available online.
Jousto: 14 days payment time, 4.90€ invoice fee. Available online.
Mash: atleast 14 days payment time, no fees. Available in store.
All payment types can be changed into part payment. More info about payment types: Race.fi: Payment types
Second tuner meet 20.6.2019
Next month, precisely at 20.6.2019 is being organized this years second tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi :) The event is cost free and for everyone.
Place: Race.fi
Link to the event: Tuner meet 20.6.2019
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 11 Juun 2019, 10:48
Why its smart to buy a D2 coilover kit
D2 coilover kit is an excellent choice for street and race, all kit has a height and 36 step damping adjustment - some of the kits has also camber adjustable top mount. Most popular sets are in our stock and others we can get usually in two weeks.
D2 has gained lots of popularity here in Finland, especially Street kit which is many peoples choice when replacing the old OEM suspension. Height and damping adjustment is excellent for all driving conditions in Finland. In the winter its possible to lift the suspension a little and in the spring lower again for example during the tire change. Damping adjustment gives much more comfort when its possible to adjust the stiffness depending what surface you drive on.
Coilover kits are road legal and we deliver our approval for the inspection, with that only the wheel alignment paper is needed (and of course the car aswell ;D). There is two years warranty on D2 street kits and it also includes the comfort warranty which means that its possible to change the spring + spring rates within 60 days of purchase, charging only shipping costs.
D2 coilover spare parts:
There are lots of spare parts available for D2 coilover kits, including springs, lock rings, dust boots and tools. We keep the most popular ones always in stock and order more regularly.
D2 coilover kits in webshop:
D2 spare parts in webshop:
»» Race.fi: D2 spare parts
Place: Race.fi
Have a great tuesday!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 02 Aug 2019, 12:25
Coming tuner meets in 2019
In this year there have been already three tuner meets and every one of them did go really well, thanks to you! But anyhow, we still have two meets left, be there or be a square!
We will offer coffee, sausages, grill and place :) Event does not cost anything and everyone is welcome there. Here is the next tuner meet with all the details.
Fourth meet
Time: 22.8.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 22.8.2019
Here is the last tuner meet in this year:
Fifth meet
Time: 19.9.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 19.9.2019
Welcome aboard!
- Race.fi staff
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 15 Aug 2019, 16:18
STRI gauges gives a precise numbers in all conditions
Stri gauges for demanding street drivers and competition use. High quality servo guarantees a precise reading in both conditions. Gauges are available in different led and dial colors.
STRI makes one of the best gauges in the market for sure! Stri DSD series has a fast and precise servo which will guarantee a precise reading even in harsh conditions. STRI DSD series is very popular in track as it runs perfectly and always shows precise numbers.
STRI gauges are very quiet, almost mute - automatic calibration on every start make sure that you can always get right numbers. Stri gauges are available in different background and led colours or with smoke or clear lens. STRI stock focus turned to the 52mm club sport models with a black dial and clear lens as they are the most popular ones. Other STRI gauges we can get fast from Europe, usually in few days.
Check Stri gauges in our webshop:
»» Race: Stri gauges
Fourth tuner meet 22.8.2019
Next month, precisely at 28.8.2019 is being organized this years fourth tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi :) The event is cost free and for everyone.
Place: Race.fi
Have a great thursday!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 16 Aug 2019, 11:08
Tuner meet next weeks thursday, 22.8.2019!
In this year there have been already three tuner meets and every one of them did go really well, thanks to you! But anyhow, we still have two meets left, be there or be a square! Next tuner meet is more specifically next weeks thursday (22.8).
Fourth meet
Place: Race.fi
Fifth meet
Place: Race.fi
Welcome aboard!
- Race.fi staff
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 04 Sept 2019, 14:36
Kaaz LSD differentials is an excellent update for all setups
Kaaz LSD is in a excellent price range as you are able to get more stability and performance for your car in racing conditions with reasonable amount of money. We also have wide range of spare parts such as friction discs and oils.
Kaaz LSD details:
- Available in Basic and SuperQ
- Fully serviceable
- High quality product from Japan
- Is in a excellent price range
- Supplied with Kaaz oils
- Usually available with 1, 1.5 or 2 way ramps
The Basic is most suitable for streets, with less preload and easier driveability that solid model, but is a great option for example for street racer. Solid version is made purely for racing conditions with stiffer preload and with more friction discs in it. Delivery time for Kaaz products is usually very fast and normally it's under a week to us from the Europe stock.
Kaaz LSD differentials in our webshop:
»» Kaaz LSD differentials
Have a great day!
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 06 Sept 2019, 11:03
Weekend offer: RVS treatments -15%
Let's put the RVS products in -15% discount for this weekend! With RVS treatments its possible to overhaul worn out engines, transmissions, differentials and power steerings for example during oil change.
RVS is a proven nanotechnology that allows sliding and extremely durable triboceramic surface in parts of engines and transmissions. Engines or transmissions condition improves right away and it is also protected from future wear. The RVS treatment will last 100,000km, so the price does not end up too bad, especially when you divide the price per kilometer.
RVS treatments can be found for all applications such as engines, transmissions, injection pumps and powersteering. Over the years, RVS has sell a lot and beginning of this week we got more stuff in our shelfs. We keep the most sellest RVS products always in stock such as diesel and petrol engine treatments.
RVS in our webshop with -15% discount:
»» RVS treatments
Next tuner meet 19.9.2019
We will offer coffee, sausages, grill and place :) Event does not cost anything and everyone is welcome there. Here is the next and this years last tuner meet with all the details:
Fifth meet
Place: Race.fi
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 13 Sept 2019, 14:16
Headlight bulbs in our webshop!
In this week we started to add headlight bulbs in our webshop and now we have some! We have added mostly H1, H4 and H7 models.
Osram and Philips bulbs, more specifically Osram Night Breaker Silver, Osram Night Breaker Laser and Philips X-Treme vision bulbs, have now arrived in our webshop. We sell bulbs mainly by pcs (like Osram), but for example Philips X-Treme visions by pair as they are always packed like that. We also added Osram Ultra life model, which has a lifetime that is four times longer than the standard halogen bulb.
More bulbs are coming in webshop from the beginning of next week and for example we are planning to add Xenon bulbs. We will also keep the most popular bulbs in stock.
Bulbs in our webshop:
»» Race.fi: Bulbs
- Riku / Race.fi
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 18 Sept 2019, 14:53
More headlight bulbs in webshop
Last week we started and this week we continued to add bulbs in our webshop. Now we have Xenon bulbs also for example with D1S socket.
We have added Osram ja Philips bulbs, for example Osram Night Breaker and Philips vision bulbs. Osrams are usually sold as pcs, but for example Philips vision series as a pair (supplier only stock this as a pair). Osram Ultra life series is a smart choice for everyday car as it has a four times bigger lifetime than OEM bulb.
Xenon bulbs are also now in webshop, with sockets D1S, D2S, D3S and D4S. Serie is Osram XENARC NBL and four times more light when comparing to the OEM bulb.
»» Race.fi: Bulbs
Have a great wednesday!
- Riku / Race.fi
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 20 Sept 2019, 10:44
Weekend offer: PLX & VEMS -10€
Lets put VEMS and PLX widebands in this weekends offer. Both are cheap insurances to the engine and for example you can get VEMS with EGT, which will show up to the same screen with the AFR - easy, right?
Today in offer: PLX and VEMS! VEMS + EGT is a excellent wideband for many cars, which has been especially favorite for turbo engines when you will see the exhaust temp from the same screen. We recommend VEMS to any highly tuned turbo car. We have sold VEMS since 2006 and overall, it is an excellent product!
The PLX wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. Both of these widebands are also a cheap insurance for the engine when you see it right away if something is wrong - not after something breaks down.
Widebands in webshop with discounted prices:
»» Race.fi: PLX widebands
»» Race.fi: VEMS widebands
- Riku / Race.Fi
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 27 Sept 2019, 11:32
Fall's seasonal products!
We have listed seasonal fall products in to our webshop in own category. Check them out!
Under "Fall's seasonal products" we have listed parts like differentials, beams, bulbs, engine heaters and care care products.
We will and have update the category in this week and there is now different kind of "medicine" for this fall and coming winter. Most popular seasonal products are in our own stock and also the ones that are not, we are usually able to get them for the next working day.
Seasonal products can be found from here:
»» Race.fi: Fall's seasonal products
Jousto: 14 days payment time, 2.95€ invoice fee. Available online.
Have a nice weekend!
- Race.fi / Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 02 Okt 2019, 14:48
More traction for winter with Quaife differential
Quaife ATB is easily the best differential on the market for street and race use! It's quiet, supplied with lifetime warranty and customer feedback has always been great.
Quaife differential is one of the greatest updates for Finnish winter and beginning of it, we usually sell lots of them. When reading the customer feedback, Quaife is more stable and has more traction when comparing to the OE diff. Differentials are made and designed in UK, where the knowledge is in a great "shape". Every Quaife unit is also tested before releasing them in to the market. They works great in every weather and usually the "yellow light" does not show up that often when there is more grip available.
We have Quaife units in stock and we order more every now and then, usually couple times a week. Most popular differentials are BMW and Mercedes models, but there is also a wide range of them for other car brands. In addition for differentials, Quaife has a high quality gear kits and transmissions available as well, ask more from our sales!
Further information and Quaife differentials in our webshop:
»» Race.fi: Quaife differentials
- Riku / Race.Fi
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 04 Okt 2019, 13:18
Weekend offer: Black Diamond brakes -15%
Lets put the Black Diamond stuff in discount for this weekend! Now it is a great opportunity to get brake parts with great price and maybe its time to do a whole brake job. In addition to brake parts, Black Diamond braided clutch hoses are also in offer.
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt, they can also be used to replace the OEM brakes. Black Diamond brake discs are available in three model, grooved, drilled or with both. The Brake pads have a great grip and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking more accurate when the balloon-like effects are reduced from the brake pedal. Brake hoses are made from RST, so they handle the Finnish weather conditions very nicely ;)
We recommend to use Black Diamonds brake fluid with brake parts so the brakes will run perfectly. Discount is in Black Diamond , but we have also wide range of outlet BD parts with up to -40% off. Most common discs, pads, hoses and brake fluids are usually in our own stock. We order more brake parts twice a week and even the most special discs arrive in less than a week.
Check the Black Diamond brakes from our webshop, prices includes discount (up to -40% off):
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond clutch hoses
»» Black Diamond brake hoses
»» Black Diamond DOT4 brake fluid
Jousto: 14 days payment time, 2.90€ invoice fee. Available online.
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 11 Okt 2019, 09:46
Weekend offer: Holset turbochargers
High quality Holset turbochargers are now in offer until next Friday, get yours!. Holset turbos are available with different sizes, so they are suitable almost for any petrol and diesel engine.
The Holset HX35 Super 8cm2 "wakes up" comfortably from lower rounds and can be always twisted to the end. The 8cm2 housing fits nicely to 1.6 - 2.0l engines and for larger assemblies we recommend the HX40 and HX50 models, which is suitable even a little bit larger engines.
Holset superchargers are available in both: Water and oil cooled models, both have their own advantages: Oil may be a bit easier to install, but water usually provides a slightly more efficient cooling, neither is a bad choice ;) Holset turbochargers are always shipped with a model specific gasket kit, which means you don't need to buy them separately unless the purpose is to grab a few pieces for the coming services. For more information and assistance in selecting turbochargers write us an e-mail or call, also the most popular turbochargers are usually in our stock.
Turbochargers with discount in our webshop:
»» Race.fi: Holset turbochargers
-Riku
RaceFi
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas RaceFi » 18 Okt 2019, 10:29
Let's put the RVS products in -15% discount for this weekend! With RVS treatments its possible to overhaul worn out engines, transmissions, differentials and power steerings easily.
RVS is a proven nanotechnology that allows sliding and extremely durable triboceramic surface in parts of engines and transmissions. Engines or transmissions condition improves right away and it is also protected from future wear. The RVS treatment will last 100,000km, so the price does not end up too bad in proportion to the benefits obtained.
RVS treatments can be found for all applications such as engines, transmissions, differentials, injection pumps and powersteering. We keep the most sellest RVS products always in stock such as diesel and petrol engine treatments, of course we will order more whenever needed.
»» RVS treatments
-Riku
Mine “Ettevõtete teenused ja sooduspakkumised”
