VW Passat B7 Variant 1.4 TSI EcoFuel - 2011 - siLc
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 23 Mär 2019, 19:35
Retrodes tuleb isiklikule heaolule ka mõelda 8)
E: Radaritele nüüd õige soft ka peale pandud. Tänud Mindfreakile. Jaht peeglitele kestab...
Kood: Vali kõik
Address 3C: Lane Change        Labels: None
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 316-05
   Coding: 0000172
   Shop #: WSC 00046 000 00000
   VCID: 3A2DCF585054D787909-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F01.03.1400H02000AMS14824ÿ
   Subsystem 4 - Serial number: S14824ÿ
4 Faults Found:
02850 - Control Module 2 for Lane Change Assistance (J770)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2013.01.01
                    Time: 00:00:00
02849 - Control Module for Lane Change Assistance (J769)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2013.01.01
                    Time: 00:00:00
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 106
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2013.01.01
                    Time: 00:00:00
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 106
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2013.01.01
                    Time: 00:00:00
Viimati muutis siLc, 24 Mär 2019, 22:42, muudetud 1 kord kokku.
Kes tänasid kasutajat siLc selle postituse eest:
Mindfreak
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 27 Mär 2019, 09:09
Paistab, et muidu kalli hinnatasemega kasutatud varuosade müüjalt FenderNetist võib vahest pärleid leida. Kuna enda masina roolinuppude volüümi üles-alla nupud jebisid aeg-ajalt kuna kasutan neid lihtsalt nii palju, siis sai väga hea hinnaga neilt ühed roolinupud ära toodud. Nupud olid väidetavalt tsut üle 3000km läbisõiduga CC pealt. Kohapeal selgus, et nupud on sisuliselt tuliuued. Kleepsul olev tootmisaeg 2017 november vaid kinnitas seda. Niiet võib rahule jääda :D
Ajaa, Alltracki komplektsed peeglid on neil ka täiesti olemas aga mõtlen veel...
Auto: Volkswagen Passat B8 R-line MY18
Tänanud: 105 korda
Tänatud: 150 korda
Lugemata postitus Postitas SanderSPS » 27 Mär 2019, 10:42
siLc kirjutas:
27 Mär 2019, 09:09
Ma ka eile vaatasin neid, aga maru kirved või ei?
Aitan diagnostika/kodeerimisega originaal Ross Tech Hex-Net kaabliga.
Uuri lisa! - www.Levwfreaks.eu
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 27 Mär 2019, 13:19
SanderSPS kirjutas:
27 Mär 2019, 10:42
siLc kirjutas:
27 Mär 2019, 09:09
Esmamõte on jah, et kirves aga tegelikult on samas hinnaklassis võrreldes sellega kui Allegrost osta praegu saadavalolevad õiges varustustatuses aga ebasobivas värvis katetega peeglid. Küljepeeglid on rasked tükid ja nende siia saatmise eest taheti 25€ per peegel.
Auto: BMW X5 3.0sd M-pakett 2008; VW Passat B6 2.0 TDI DSG Highline 2008; Nissan Navara 2.5dci 2007a.
Tänanud: 92 korda
Tänatud: 92 korda
Lugemata postitus Postitas TiitRE » 27 Mär 2019, 13:23
siLc kirjutas:
27 Mär 2019, 13:19
Kui raske see küljepeegel siis on?
Mul tulid mõlemad täiskomplektsed esituled ja saatmine (2tk. korraga siis) 35.-
aus
Telefon: 5238749
Auto: VW Passat B7 4Motion (MY 2014) | Passat Variant B6 4Motion (MY 2006)
Tänanud: 72 korda
Tänatud: 69 korda
Lugemata postitus Postitas aus » 27 Mär 2019, 13:29
Poolakas keevitab lihtsalt hinda, ei viitsi tegeleda eestlasega. Esimest korda tellite v? :D
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 27 Mär 2019, 14:34
TiitRE kirjutas:
27 Mär 2019, 13:23
siLc kirjutas:
27 Mär 2019, 13:19
Kui Fenderis peegleid käsitsesin, siis üks peegel kaalus käe järgi 1-2kg. Osad poolakad küsivad lõdvalt 70zl ehk mingi 17€ juba poolekiloste või veel kergemate asjade saatmise eest...
Saatmine kindlasti oleks odavam kui mõlemad peeglid saaks ühe müüja käest aga paraku pole saanud saanud jutule. Mu kodustatud poolakad ka meilidele ei vasta, et nende vahendusel kaup siia saada :crazy:
Tänanud: 92 korda
Tänatud: 92 korda
Lugemata postitus Postitas TiitRE » 27 Mär 2019, 16:36
aus kirjutas:
27 Mär 2019, 13:29
Mul oli küll 1. kord jah :D
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 28 Mär 2019, 17:07
Õumaigaaad, mis joppamine! Tõin Fenderist need Alltracki peeglid ära, mida reklaamiti kui 11+2 ja 9+2pin. Jõudsin koju, hakkasin peegleid puhtaks küürima ja mõtlesin, et võiks ka pinnid kokku lugeda - tegelikkuses on 15+2 ja 13+2, ehk siis peeglid on täispauk varustuses ! Ma veel arvasin, et tuleb hakata peeglimäludega jebima aga kõik on plug-and-play nüüd ja hinna tegi isegi suht magusaks arvestades kui värskete tükkidega tegu :D
Viimati muutis siLc, 28 Mär 2019, 17:11, muudetud 4 korda kokku.
volkar
Tänanud: 92 korda
Tänatud: 92 korda
Lugemata postitus Postitas TiitRE » 28 Mär 2019, 18:13
Good! ;)
Tänanud: 120 korda
Tänatud: 133 korda
Lugemata postitus Postitas tito » 29 Mär 2019, 06:48
Ole hea ja paranda siis ära see kallis ja asenda imeline Fendernet :D
Ma olen Fenderist ostnud ja soovitanud teistele- tõsi ju on et veidi kallim, aga ma pole ka kunagi kuulnud et mingi jama oleks. Kui on defektne varuosa või et üleüldse väga defektseid liigub ( no mõnede stangedega on meil jama olnud aga alati on leitud kompromiss ) on lahendused neil alati olemas.
Kes tänasid kasutajat tito selle postituse eest:
volkar
ехали, ехали, ехали и приехали
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 29 Mär 2019, 08:57
tito kirjutas:
29 Mär 2019, 06:48
Ära saa valesti aru - FenderNet pole halb, lihtsalt nende hinnastamise loogika vahest ei ole mõistetav. See kuu neil -30% ja asjad juba päris okei hinnaga. Asjaajamise osas pole ka midagi halba öelda kuna isegi kui ise mingi prohmaka teinud, on nad vastu tulnud ja asi lahenenud.
Peeglid said külge. Varsti teeb pilti ka...
highway2hell
Telefon: 5102926
Auto: VW Passat b8, VW Golf 1
Tänanud: 0
Lugemata postitus Postitas highway2hell » 29 Mär 2019, 17:34
OT: Tänud, et fenderneti meelde tuletasite, vaatasin huvi pärast, et mida mulle pakutakse.. peeglid on hetkel liiga kallis väljaminek, aga puuduoleva webasto puldi tellisin kohe ära :D
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 29 Mär 2019, 20:56
Küll käivad asjad kiiresti. Magnus tegi peeglid puldist klapitavaks aga pilti ikka pole ma jõudnud teha...
Küll aga tekkis vajadus vahetada välja peeglite nupp sellise vastu, millel oleks klappimise asend ja mis läheks kokku kliimaploki ja disco uue stiilis keeratavate nuppudega. Võibolla isegi mitte nii väga üllatuslikult tuli jälle appi FenderNet, kust hea hinnaga õige tükk ära tellitud sai.
Homme plaanis Side Assisti tulukeste juhtmestiku lõpuni ühendada ja järgmine nädal saab Ülemistel radareid kalibreerimas käia, siis võib sellele retrofitile kriipsu alla tõmmata. Päris palju asju sai korraga tehtud :mrgreen:
Vanad peeglid pakun müügiks: Värvus LC8Z ehk Mocca Brown, juhipoolsel soojendus, lombivalgus ja isetumenev peegliklaas, kundepoolsel soojendus ja lombivalgus. Kirjuta privaatsõnumisse kui on huvi.
Viimati muutis siLc, 29 Mär 2019, 21:04, muudetud 1 kord kokku.
Tänanud: 92 korda
Tänatud: 92 korda
Lugemata postitus Postitas TiitRE » 29 Mär 2019, 22:14
Guugeldasin seda imelooma Fendernet´i ja tegu siis pmst. lammariga jah?
Miks küsin? Kuna tundub, et tegelevad orig. juppidega, siis ei tea, kas ostavad sisse ka OE juppe? Mul jäävad kohe üle terve ring orig. tulesi koos vajalike plokkidega ja peaks neid kuhugi pakkuma.
Tänatud: 55 korda
Lugemata postitus Postitas siLc » 29 Mär 2019, 22:36
TiitRE kirjutas:
29 Mär 2019, 22:14
Nad ei ole klassikaline autolammutus, mis kohapealse sõiduki sisse ostab ja osadeks teeb, vaid nad ostavad saksast euroalusel poolekslõigatud sõiduki sisse ja müüvad selle juppideks. Ma pakkusin oma peegleid aga öeldi ära.
Vvariant
Tänatud: 24 korda
Lugemata postitus Postitas Vvariant » 30 Mär 2019, 11:08
Lihtsalt huvist, kas kaskole on ka vajalik kõigi nende pudinate külgeriputamisest teatada? Lihtsalt mõtlen, et kui neid lisasid kuskil ametlikult kirjas pole, siis korralikuma kaskojuhtumi puhul taastatakse detaile vist VIN koodi järgi, ehk pannakse külge need detailid mis tehasest tulid ja ehk nullitakse suur osa sellest teemast.
Viimati muutis Vvariant, 30 Mär 2019, 11:08, muudetud 1 kord kokku.
Tänanud: 120 korda
Tänatud: 133 korda
Lugemata postitus Postitas tito » 30 Mär 2019, 12:31
Eem, pigem on see ikkagi kindlustuse kohus taastada olukord mis oli ennem avariid. Mis muidugi ei tähenda et mingid nurgatagused tuima näoga originaaliks ei taasta.
Tänanud: 92 korda
Tänatud: 92 korda
Lugemata postitus Postitas TiitRE » 30 Mär 2019, 12:42
tito kirjutas:
30 Mär 2019, 12:31
Nurgatagused sul hui originaali taastavad, ikka kõige odavam b-grupp külge ja raha siia.
Aga olen mõnda sellist juhtumit lugenud foorumitest ja sealt koorub välja, et lähenetakse ka ikkagi igale juhtumile personaalselt ja arvestatakse ka (tõendatud) lisavarustust (kasko pakkujast oleneb ka muidugi väga palju).
Tänanud: 26 korda
Tänatud: 253 korda
Lugemata postitus Postitas jussike » 30 Mär 2019, 14:03
Külge läheb ikka see, mis laksu hetkel oli. Egas kindlustus tea mis komplektsuses auto tehasest välja tuli. Seda uuritakse heal juhul siis, kui terendab mahakandmine ja hüvitisega nõus pole.
Kui nüüd lisad auto väärtust tugevalt tõstavad, siis oleks isegi mõistlik kindlustust teavitada, nii saab ka kindlustusväärtust tõsta. Mina oma CC-ga tegin nii. Leping tehti ümber ja imekombel makse hoopis vähenes, kuigi auto kindlustusväärtus tõusis paar tonni.
Vvariant
Tänatud: 24 korda
Lugemata postitus Postitas Vvariant » 30 Mär 2019, 15:01
Seda peangi silmas, et kaskolepingutes on koht, kuhu saab lisada tehasevälise varustuse, kas lisatud mingeid keredetaile, elektroonikat või muud mudru. Kui see mingit väärtust ei omaks, siis tekib küsimus milleks seda siis küsidagi.
Et ostad vändakendega trendline, teed selle Highlineks, kasko ei muutu (ometi kallimaid detaile mis puruneksid on küll ja veel) ja maks läheb ehk odavamaks. Does not compute.
Tänanud: 26 korda
Tänatud: 253 korda
Lugemata postitus Postitas jussike » 30 Mär 2019, 18:02
Kuda võtta, OEM lisad pole ju otseselt "tehase välised". Seal peetakse ikka silmas mingeid tuning detaile või jämedamat stereot, ka firmade logod/kleebised. Üldjuhul on piir tavaliselt 1000€, mille puhul ei pea kindlustust teavitama, üle selle oleks mõistlik. Mäletan juhust, kus kliendil lepingus oli selleks piiriks 600€ pandud, (oli tegemist firma logode taastamisega) paraku oli kleepimise hind üle selle ja kindlustus korvas sellest ainult 600 ja ülejäänud pidi ise plekkima.
Tänanud: 120 korda
Tänatud: 133 korda
Lugemata postitus Postitas tito » 30 Mär 2019, 18:25
TiitRE kirjutas:
30 Mär 2019, 12:42
Nurgatagustega on just see, et need saadavad vin koodi ja saavad enda oem/b osad. Mis pärast selgudes polegi õiged.
Viimati muutis tito, 30 Mär 2019, 18:26, muudetud 1 kord kokku.
Ussike
Auto: VW G2
Lugemata postitus Postitas Ussike » 30 Mär 2019, 19:21
Ega see probleem ei vaeva ainult nurgataguseid kui omanik oma nokka lahti ei tee ja ei ütle et ta auto on paras lego ja jumal teab millest kokku pandud.Esimese ehitaja puhul on kindlasti asi lihtsam,oskab tähelepanu juhtida aga hiljem edasi müügi järel....
Tänanud: 105 korda
Tänatud: 150 korda
Lugemata postitus Postitas SanderSPS » 30 Mär 2019, 19:35
Vvariant kirjutas:
30 Mär 2019, 11:08
Tead ma võin sellest teemas pikemalt kirjutada.
Ideaalis peab kindlustusele teatama lisavarustuse ostmisest. Selles mõttes nt valuveljed. Ma kirjutasin PZUle ka pika kirja teemal lisavarustus ja retrofit. Tõmbas tüübid kaameks näost ja kirjutasid aasta kaskole otsa ligi 200 euri. Ja tüli algas. Viitasin ka sellele, et kasutatud on originaaljuppe ja tehasest tellides on paigaldus üks ühele või parem. See neid ei morjendanud.
Minu jaoks on oluline tehnilise rikke kasko. IF on teine kes pakub kuni 150000 ja kuni 6 aastastele masinatele. Kirjutasin neile pika kirja oma tegemistest ja helistas tagasi Helina nimeline neiu. Üliiiiiii äge neiu. Ta oli käinud 2 korda uurimas mingitelt pagunitega vendadelt ja ütles vaid, et loeksin talle nimekirja ette mis ma teinud olen ja paneb lepibgusse erisuste alla kirja. Kasko tuli soodsam kui pzu oma. Tingimused paremad ja pmst iga viimane kui üks retrofit läheb kasko alla. Win Win.
Pzu tahtis neid retrofitte lisada kategooriasse ostu järgselt paigaldatud lisad, ehk need on siis tavaliselt 1000 v 1500 väärtuses kindlustatud. IFi vastutulek oli vägev.
