Kas keegi teab mis need veakoodid täpselt tähendavad .
p1116
p1196
p1183
golf 4 mootori tuli
Petzo
- Telefon: 55596240
- Auto: Golf II
- Tänatud: 28 korda
Re: golf 4 mootori tuli
Esimene peaks siis selline olema. Teisi ei leidnud
17524/P1116/004374 - Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1: Open Circuit
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19)
Check/Replace Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19)
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Rait.
