LIsan ka autoscani mille tegin ise enne dignostikasse viimist, ehk oskab keegi midagi arvata. Enamus nendest vigadest tekkis selle mootori jamaga.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5D-Operations -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 MR HW: 028 101 211 9
Component: R4 2,0L EDC G000SG 9389
Coding: 0000072
Shop #: WSC 00011 888 81093
VCID: 7BF47A483A31849EDF-802E
Subsystem 1 - Part No: 03G 906 021 MR
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658174812
Coding: 0029986
Shop #: WSC 05311 000 00000
VCID: 306E9D64A3F7B7C63A-8064
No fault code found.
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002156658
Coding: E78A8F0700041A00000A00000F000000000B5D435C0000
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00217165
Shop #: WSC 05311
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:00
Freeze Frame:
ON
Voltage: 13.60 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 P HW: 3C0 909 605 P
Component: 01 AIRBAG VW8 033 2522
Revision: 13033000 Serial number: 003CWPBR6QX3
Coding: 0012337
Shop #: WSC 46078 123 56531
VCID: 3364926852E18CDE47-8066
Subsystem 1 - Serial number: 6332MSME0B470571
Subsystem 2 - Serial number: 6342MSME0A3A2054
Subsystem 3 - Serial number: 6351HTS65CHEOM43
Subsystem 4 - Serial number: 6361HTS65CHIEN43
Subsystem 5 - Serial number: 6371VTS614F6PMC2
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 B HW: 3C0 953 549 B
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507E
Coding: 0000312
VCID: 2B548A088AD1D41E0F-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 G HW: 3C0 920 870 G
Component: KOMBIINSTRUMENT VD1 4038
Revision: V0033000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 00011 888 96745
VCID: 275C76389639F07EEB-8072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:40
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C059100C4F
Coding: 7DFDAC54E62002
VCID: 21486820F81D0E4EA5-8074
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 243299 km
Time Indication: 0
Date: 2017.12.27
Time: 10:04:15
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 253255 km
Time Indication: 0
Date: 2018.06.13
Time: 16:43:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:13
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 326AFB85D64C-8066
Subsystem 1 - Part No: 3C0 905 861 C
Component: ELV 023 0350
3C0905861C ELV 023 0350
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0000247
VCID: 377CA678469960FE7B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
1 Fault Found:
Freeze Frame:
Mileage: 7520 km
Temperature: 13.0°C
Voltage: 13.30 V
Voltage: 13.20 V
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 3C0 035 456
Component: 08K Audioverst. 0003
Revision: 00001000 Serial number: 00000000003093
VCID: 5DB014D084E56AAEC1-8008
2 Faults Found:
00875 - Treble Speaker Front Right (R22)
00877 - Treble Speaker Rear Right (R16)
012 - Electrical Fault in Circuit - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000246
VCID: 387EA5444B876F8672-806C
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000012
Shop #: WSC 00046 000 00000
VCID: 26427B3C9133E976D0-8072
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 242
Mileage: 257552 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:40
Freeze Frame:
Voltage: 13.25 V
Count: 241
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000001
VCID: 71E85860687DFECE75-8024
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 242
Time Indication: 0
Address 56: Radio
Cannot be reached
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 B HW: 3C0 035 151 B
Component: J738 010 0018
Revision: 00010000
VCID: 173C46F8265940FE5B-8042
Address 62: Door, Rear Left
Cannot be reached
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Coding: 0000001
Shop #: WSC 05314 000 00000
VCID: 6ADA4F0C45AB0D1634-803E
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 242
Mileage: 257556 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:00
Coding: 0000072
No Faults Found
Coding: 0029986
Cannot be reached
Coding: 00065493
Shop #: WSC 05311
Coding: 00217165
Shop #: WSC 05311
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:00
Freeze Frame:
ON
Voltage: 13.60 V
ON
ON
OFF
OFF
OFF
Coding: 0012337
Coding: 0000312
Coding: 0005105
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:40
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 243299 km
Time Indication: 0
Date: 2017.12.27
Time: 10:04:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 253255 km
Time Indication: 0
Date: 2018.06.13
Time: 16:43:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 257559 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:13
Cannot be reached
Coding: 0000247
1 Fault Found:
Freeze Frame:
Mileage: 7520 km
Temperature: 13.0°C
Voltage: 13.30 V
Voltage: 13.20 V
Cannot be reached
2 Faults Found:
Coding: 0000246
Revision: 013
Coding: 0000012
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 242
Mileage: 257552 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:40
Freeze Frame:
Voltage: 13.25 V
Count: 241
Coding: 0000001
Coding: 00000035
Coding: 00000035
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 242
Time Indication: 0
Address 56: Radio
Cannot be reached
Revision: 00010000
Cannot be reached
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 242
Mileage: 257556 km
Time Indication: 0
Date: 2018.08.06
Time: 06:57:00
