Selline anomaalia siis.
Keset sõitu kaovad ära voolud, tuled, suunadtuled, raadio, vent, kojamehed jne. Tööle jäävad pidurituled ja kui keerata päevatuledele siis süttivad ka tuled.
Mootor jään ilusti tööle.
Kui keeran süüte välja ja uuest tööle, siis kõik toimib jälle. Kuni järgmise korrani- juhtub pea 5 korda päevas.
Lisan ka veakoodid, mis välja raalisin.
Wednesday,20,July,2016,17:31:38:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WV1ZZZ2EZA6022173 License Plate: LOOTON
Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB) Labels: None
Part No SW: 076 906 022 N HW: 076 906 022 G
Component: R5 2,5L EDC A020SG 9021
Revision: 24H32--- Serial number: VWXDZ0J1003641
Coding: 0003072
Shop #: WSC 10660 002 1048576
VCID: 1E3338F3CA420EEE86F-5072
6 Faults Found:
006457 - Powertrain Databus
P1939 - 000 - Missing Message from Controller for Access & Start Auth. - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Voltage: 14.14 V
Voltage: 14.14 V
Voltage: 14.14 V
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 50
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Readiness: 0 2 0 0 0
Address 91: LT3 Engine Labels: None
Coding: 0003072
VCID: 1E3338F3C9420EEE86F-804B
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Voltage: 14.14 V
Voltage: 14.14 V
Voltage: 14.14 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 50
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Torque: 0.0 Nm
Temperature: 86.4°C
Bin. Bits: 00010000
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 AD HW: 906 545 580 8
Component: IMMO 0805 0815
Revision: 00805000 Serial number: VWXDZ0J1003641
Shop #: WSC 00000 000 00000
VCID: 6DD12F3F746425764F5-8038
No fault code found.
Address 94: LT3 Airbag Labels: None
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3332.rod (*)
VCID: 55A167DF34F48DB6975-8000
Address 95: LT3 ESP Labels: None
Part No SW: 9069022800 HW: 0004460153
ASAM Dataset: 3 4101
ROD: CRFT_ESP_3_4101.rod (*)
VCID: 04076A9B8FEEC43EB0B-8051
3 Faults Found:
475C - CAN message ID240h Electronic Ignition Switch (D9): failed
MIL ON - Test Complete - Stored
472D - CAN message ID408h Instrument Cluster Control Module (J285): failed
7240 - CAN Electronic Ignition Lock (D9): Message periodically not received
Address 96: LT3 Instruments Labels: None
Part No SW: 9069024700 HW: 9069011800
ASAM Dataset: 32 786
ROD: CRFT_KOMBI_32_786.rod (*)
VCID: 0501779F84D4FD36A75-8050
Address 99: LT3 Ign. Switch Labels: None
Part No HW: 9065455808
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
2 Faults Found:
9009 - Terminal 15C: Implausible signal
9007 - Terminal 15: Implausible signal
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 0815
Revision: 00805000 Serial number: 12345678901234
Address 9B: LT3 Driver Door Labels: None
Part No HW: 9068205626
ASAM Dataset: 33 260
ROD: CRFT_FTUHR_33_260.rod
Address 9C: LT3 HVAC Labels: None
Part No SW: 2514450200 HW: 9068300985
ASAM Dataset: 21 514
ROD: CRFT_KLIMA_21_514.rod (*)
VCID: F7FD8D574E381FA6259-80A2
1 Fault Found:
9304 - Temperature flap motor underfloor system: defective/open circuit/short circuit
Address 9E: LT3 Aux.heat (elec) Labels: None
Part No HW: 9064460029
Shop #: WSC 131071 1023 2097151
ASAM Dataset: 84 769
ROD: CRFT_PTC_84_769.rod (*)
Address 9F: LT3 Stat.heat (water) Labels: None
Part No HW: 9064460629
ASAM Dataset: 98 257
ROD: CRFT_STH_98_257.rod (*)
3 Faults Found:
902C - Tank content too low: CAN signal below barrier
D030 - CAN data bus: No communication
D031 - Electronic ignition switch (D9): no signal / no communication
Address B1: LT3 Upper Console Labels: None
Part No HW: 9065453607
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
1 Fault Found:
9021 - Instrument Cluster Control Module (J285): No communication
Address B3: LT3 Trailer Module Labels: None
Part No HW: 1695455632
ASAM Dataset: 21 4
ROD: CRFT_TRL_21_4.rod (*)
Address B4: LT3 Central Elec. Labels: None
Part No SW: 9064420700 HW: 9065453801
ASAM Dataset: 33 772
ROD: CRFT_EZE_33_772.rod (*)
3 Faults Found:
9090 - Terminal 15R; monitoring: Implausible signal
9091 - Terminal 15; monitoring: Implausible signal
9099 - Terminal 54; brake pedal monitoring: Implausible signal
Address B6: LT3 Steering Wheel Labels: None
Part No SW: 9065402545 HW: 9065402545
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 081F7EABB3C6E05EDC3-805D
End ---------------------------------------------------------------------
Crafteri elektri probleem
- Telefon: viiv551171null
- Auto: Crafter 2,5tdi 100kw 2011
Re: Crafteri elektri probleem
kas leidsid lahenduse?ma olen sama lõhkise küna ees mul vaid diagnostika näitab et treiler moiduliga koik ok,aga tuled ei taha toimida on vaid piduri tuli,vigasid aga ei näita...
Tühja-Tähja tootmiskoondis
Restuaureeritud Webasto komplektid "plug and play" ja ole soojas.
Kergkaubariiulud-koju-garaazi-keldrisse-tööstusesse
ma sain oma sellele konnale pihta.Mul nimelt oli haige 1 releedest mis terminaal 15st toitis vahetasin ärea ja asi kombes.Need hetkelised elekri katkestused peksid pool bussi elektroonikat segi.
