Passat B8 ja rear assistant viga
janhen
Auto: Golf VII CL
Lugemata postitus Postitas janhen »
Kirjeldan probleemi ja äkki oskab keegi aidata.
Juhiabidest ei ole võimalik aktiveerida rear side assistanti,
Kaabliga sain veateated, mis võivad olla probleemiga seotud.
Nagu aru saan, siis puudub suhtlus CAN ja radari vahel.
Enne, kui tormata ostma radarit, mõtlen valjult, et äkki võib olla probleem hoopis
juhtmestikus, või, millegipärast ei tunne auto (enam) radarit ära ...
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 3204675A59FFC428949C804D
Shop #: WSC 05311 115 00092
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X_VW48.rod
VCID: 34616A179FF45981BA7-8061
1 Fault Found
0800 - Databus
U1123 00 [009] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 6
Reset counter: 133
Mileage: 128783 km
Date: 2020.10.14
Time: 15:23:53
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 18101510802566
Coding: 0B0300345F087300FB00025A1C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_VW37.rod
VCID: 79FF9B23F81664E9291-802C
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002030850075421
Coding: 2FFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 8642608103
Inverter power receptacle:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H56 0033
Serial number: 0152172
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
1 Fault Found
131722 - Control Module 2 for Lane Change Assistance
U10A5 00 [009] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 135
Mileage: 128799 km
Date: 2020.10.22
Time: 09:24:47
Address 3C: Lane Change (J769) Labels: None
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
ROD: EV_RearRadarS1BoschVW48X.rod
VCID: 377B5D1B8E82B2999F5-8062
1 Fault Found
1179653 - Local Data Bus
U10BA 00 [009] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 128799 km
Date: 2020.10.22
Time: 09:26:39
Aspiriin
Telefon: 5591null66kaks
Auto: VW Passat 2017 4M, Highline
Tänanud: 20 korda
Lugemata postitus Postitas Aspiriin »
Labels: Redir Fail!
Oled mingeid vastseid leidnud sellele?
Mingid foorumid räägivad, et ei leia
Moodul õiget faili ülesse...
Sorry aga huupi pakkumine hetkel..
janhen
Auto: Golf VII CL
Siit lehelt:
https://www.tsbsearch.com/Audi/96-12-46
loen välja et minu juhtumi puhul on ikkagi master control unit ehk J769 õhtul?
See, et veateate annab ka püsikiirushoidjale J428, on ka loogiline,
kuna asetsevad ühtses süsteemis:
http://www.vaglinks.com/vaglinks_com/Do ... istent.pdf
