Sunday,08,November,2015,17:44:58:01666
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
http://www.Ross-Tech.com" onclick="window.open(this.href);return false;
VIN: WVWZZZMIDAVÄRKI License Plate: VOLKAR
Mileage: 169750km-105477mi Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
65 69 6C 72 77
VIN: WVWZZZ3CZ7P129158 Mileage: 169750km-105477miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9248
Revision: --H06--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 7AFB00AD35D9DBEE13-802E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795617532
Coding: 0002305
Shop #: WSC 12345 123 12345
VCID: 62CB58CDBD49332E2B-8036
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AJ HW: 3AA 907 044 AJ
Component: Climatronic H03 0404
Revision: 00001K02
Coding: 0019004808
Shop #: WSC 12345 123 21345
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 78FF1AA5C3D5C9FE65-802C
1 Fault Found:
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 169759 km
Date: 2015.11.08
Time: 00:41:22
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008732296
Coding: FC002A8F00000000DF0000630F0000008019FF7F7F000004004000000000
VCID: 3365ED895233EAA690-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 281106 003 0205
Coding: 00049045
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110213 054 0403
Coding: 09408552
Shop #: WSC 12345
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35831413600268
Coding: 318001
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 3365ED899A33EAA690-8066
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1P160ZJF
Coding: 0012354
VCID: 306FE285A325D1BEED-8064
Subsystem 1 - Serial number: 6332MSME15315C29
Subsystem 2 - Serial number: 6342MSME16386566
Subsystem 3 - Serial number: 6351HTS6GIE0EA77
Subsystem 4 - Serial number: 6361HTS6GIEKAJ77
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0200711
VCID: 72EB288D6DA9A3AE5B-8026
Subsystem 1 - Part No: 3C8 959 537
Component: E221__MFL-TAP H1˙ 0020
Coding: 00000227
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 981 D HW: 3C8 920 981 D
Component: KOMBI H04 0611
Coding: 160F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 2F6DE1F9761BCE46F4-807A
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 270314F2002662
Coding: 461006
VCID: 7CF706B5FFEDE5DE01-8028
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 042 0399
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 00857 461 999999
VCID: 76E3149D01C1BF8E77-8022
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 3C8 035 680 B
Component: RNS-MID H27 6276
Revision: AB001001 Serial number: VWZ6Z7P9332151
Coding: 00000400040000A10000
Shop #: WSC 01357 011 00200
VCID: 3D71CBB1A4772CD676-8068
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V13 8350
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000524978127
Coding: 0000245
VCID: 3B75C5A97A6322E648-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
VCID: 3467EE95573DED9E89-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 042 0631
Coding: 18910A000186403F0002951570080F0B607C40
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 00000008
VCID: 6FED21F9BE9B8E46B4-803A
Subsystem 1 - Part No SW: 3AD 919 204 A HW: 3AD 919 204 A
Component: Analoguhr 003 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000555078123
Coding: 0000244
VCID: 3C77C6B57F6D25DE41-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000248059
Coding: 0000057
VCID: 2C57F6F58F0DB55ED1-8078
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 020E185A
VCID: 71E92781A8AF98B6A2-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1118
Revision: 11006001 Serial number: 00000001227586
Coding: 0000080
VCID: 3D71CBB164772CD676-8068
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000179043
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_VW36.rod
VCID: 3561D3919447F496BE-8060
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000113173491
Coding: 0100000100000000
Shop #: WSC 01316 785 00200
VCID: 2F6DE1F97E1BCE46F4-807A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H08000 Serial number: 525PA8-J0Y1078
Coding: 0030006
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1118
Revision: 11006001 Serial number: 00000001266367
Coding: 0000080
VCID: 3E73CCBD697137CE6F-806A
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105172200
Coding: 020000010100110000000100
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 24471ED52FDD7D1E19-8070
End-------------------------(Elapsed Time: 03:06)--------------------------
